#106
i didnt really want to show pics yet but why not i guess
.... note i have all black couplers on the way. Need to trim away the license plate mounts but otherwise its a perfect stealthy fit wait intercooler, what intercooler?
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#107
Also, i will be using a drycell battery, and it fits in the engine bay just fine.
phil
#108
phil
#109
What brand/model will you use?
#110
phil
#111
are you sure that FMIC is going to be big enough? I am told that Mr. SVXFiles tried running one of similar size only to find that it was too restrictive....
TOP SECRET SPY PHOTO FROM THE SVX R&D CENTER
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$ Last edited by SVXelerator; 01-09-2006 at 06:03 PM. |
#112
I was curious because I'm thinking of trying one of the Odyssey PC925MJT batteries.
#113
Got the oil pan off to run the return today, and on a good note the rest of the parts showed up. The Greddy Oil filter adapter is pretty handy. Got my couplers and T bolts as well.
I Took my time in cleaning everything in the parts cleaner, and getting the old gasket off the block and the oil pan. Quote:
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. Last edited by Phast SVX; 01-09-2006 at 09:01 PM. |
#114
phil
#115
Its 6.7" long x 7.1" wide x 5.0" tall. Weighs only 26 lbs. 380 CCA, but 925 pulse crank amps.
#116
It did slow me down and choke the flow ALOT, but with an axial vane SC, there is really not enough heat to worry about. With my (5) phenolic spacers, and the 3" X 48" exposed aie transfer tube, the intake manifold never got over 170f, on a close to 100f degree day!
#117
phil
#118
Where i measure boost is in the airbox, just outside the throrrle body. After I changed pulleys and intake tubing again I was hitting up to 9 psi at WOT. I believe the restriction was the tiny air passages in the intercooler.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 01-10-2006 at 11:26 AM. |
#119
Ya, the air passages looked narrow in the picture that guy posted. Phil's looks to have a much larger cross section. The passages are much thicker and wider. Of course there should be a fair pressure loss with an intercooler. That's kind of the whole idea. With a turbo's abiatic efficiency around 65% 35% of the pressure increase is due to heat-the job of the intercooler is to remove that heat so if it were completely efficient you would loose 35% of your manifold pressure while maintaining the same intake volume.
#120
comparison for you:
