#106
Re: Camshafts for the EG33.
As Bazza has no idea what the cams that he wanted, ended up like, we have to guess that they were ground on the same centers as the standard cams, if so the timing would look like this. ![]() Blue is the inlet valve, yellow is the exhaust valve. The engine rotates clockwise. With such a long duration the overlap works out to be 45*. This means that when the inlet opens at 20* BTDC and for the next 45* the exhaust valve is still open, So the inlet boost is blowing straight out the exhaust valve and down the.exhaust pipe. This is a waste of all the compressed air, that should have stayed in the cylinder building torque. The other end of the inlet has the valve closing at 70* ABDC. This timing is suited to a high revving engine, that would develop peak torque at about 7000 rpm, this is too high for the rev range that you are running. Closing at 65* would be the most you would need. As I keep saying you need as much lift as you can build into the engine. 8.75 mm is attainable with hydraulics, you missed the chance to do it. Shorter duration and more lift would have more boost filling the cylinder, producing the torque that it should have. Harvey.
#107
However you're still trying to claim the stock cams are awesome. Mate - they're ****, time to move on from 1935 and get with the times. Quote:
Simply put, you're the last person I will listen to about cams or anything else auto for that matter. Everything to date you've said and done has been wrong and a failure and you've got nothing except grey hair and a well worn keyboard. I ignored your advice with the cams, I came up with my own setup and it's worked extremely well. Think that is the moral of the story for the members - ignore Harvey if you want a cost effective and high performing setup. Listen to him and you'll go nowhere. Also I could shoot your bull**** to pieces above because it's so full of holes it's not funny but it's not worth it. ROFL - turbo making peak torque at 7000 rpm - you're funny. Again showing how lack of any sort of clue you really have. |
#108
Careful gentlemen, the mods are going to end up sending you to your rooms
![]() ![]() What I'm seeing is the two curves should not be seen as an apples-to-apples comparison (100RON, 7 psi, no timing (new cams) vs 14 psi, E85 and timing (stock cams) ). More variables than we have equations ![]() I believe - and am willing to be corrected if I'm off base - that we can all agree that the EG33 likes more lift and that 8.75 mm is the upper limit with the stock springs/valves for the int and exh. The duration and overlap of the int and exh cams appears to follow well established principles wrt building pressure vs blowing fuel out the tail pipe (?). This leaves us with the question of what duration/overlap works best for NA and FI application. I'd like to believe that the cams I have in my EG33 are "close" for NA applications, acknowledging that they could have slightly more lift (in the tenths/hundreths of mm). I also acknowledge that dyno runs are necessary to make any quantitative conclusions here. Need to cut the hood and get the car to the tuner/dyno!! On the FI front, we have TOMSSVX supercharged EG33 and Bazza's turbocharged EG33. I believe Tom J had his engine on a dyno before he sold the car, but I've got to dig through my files to find my spreadsheet with dyno results. Bazza has track results that we can start extrapolating engine performance. Think we're heading in the right direction here! Last point -- Harvey! Can you run your EG33 computer simulation to determine what the effect on torque peak is of increasing intake path length in increments of 25mm? Thanks. Bill
#110
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#111
![]() Harvey.
#112
The Vmax is absolutely amazing at 7 psi. I forgot I've added about 50kg of weight since last time which means power to weight even - the Vmax would be better at 7 psi (100RON) rather than the old 14 psi E85 setup. This isn't apples v apples - it's better - it's shows that these cams have huge potential and it shows I was right every step of the way thus far. Quote:
Now, have you tested the intake lift at 8.75mm? I'd be very careful and ensure you get it right or you'll be up for a lot of coin replacing the valves with longer ones to fill the clearance and or replacing springs and sorting out journal clearance issues. With my chosen profile - there is no way to get more lift (7.9mm intake) without sacrificing duration etc OR needing to replace the valves ($750) to solve the clearance issue OR weld the cams ($1500) - I am on the absolute limit of what was possible with them with the masters my cam shop had. Quote:
With turbo cams, it's far better to find something that works and use those ideas. The EG33 is so under-developed as opposed to it's EJ cousin and is about 10 years behind in the mods world. It's therefore far better to use the EJ concepts, catch up and THEN start innovating. EJ cam combinations have been proven 1000 times over. My cams are simply stage 1 - they work and the engine now revs like the EJ - obvious benefit is I make more power at 7 psi than they do at 20 psi ![]() When I get around to developing stage 2 - then I'll look at maximising lift, duration. Luckily for me a mate of mine is running those 330/320 advertised with a lot of lift and duration - so he is the guinea pig for my stage 2 setup. Last edited by bazza; 11-06-2012 at 06:54 PM. |
#113
I just don't deal well with people with far less experience or knowledge telling me how to do something or what I've done is wrong and I especially don't deal well with keyboard warriors or cheque book racers for that matter. Always happy to listen to all advice as only an idiot would close his eyes and ears and ignore reality.
#114
Frankly, I'm not quite knowledgeable enough to tell whether one of you is actually right or wrong, or both right somehow, and the people who run the place probably can't tell either, and don't care. So keep it friendly, guys.
#115
Comments such as "As Bazza has no idea what the cams that he wanted, ended up like, we have to guess that they were ground on the same centers as the standard cams, if so the timing would look like this. " deserve the exact response they received. If Harvey wants to act like a 10 year then I will treat him like one. http://www.subaru-svx.net/forum/show...&postcount=106 |
#116
Bazza!
Comments inserted below. Cheers Bill Quote:
#117
It's actually quite polite compared to how most blokes especially mates talk to each other
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
#118
What I'll do next time out (early December) is a few 7 psi runs, 10 psi runs, 12 psi runs and if the stock clutch will handle it 14-16 psi. All down the main straight. I've set up a sector from the start to brake point and can already see some interesting things in the data logging software. It's called GPX Pro / XT Studio if you're interested. I've probably spent 10+ hours of time on it since Friday's track day researching/analysing and updating the numerous spreadsheets / databases I have. It's a very cool tool especially from a bigger picture when you can see suspension changes / engine changes / gearbox changes / aero changes all showing up. Quote:
![]() Quote:
#119
Bazza,
Gotcha on the TS database! ![]() Looking forward to seeing the results of the December runs! I checked out the GPX Pro / XT Studio site. Looks good! Are you running the 4 or 8 channel version? What, exactly, are you datalogging? I'm very interested in how you've got the car wired up and what sensors you're using (yeah, it's the "test and evaluation engineer" part of me rearing its head! ![]() -Bill Quote:
#120
The cams that I have, I know nothing about except what's in my signature:
244,8.1mm/256,9.1mm intake/exhaust Do you guys think they will be an ok match for the turbo engine? The choices are either these or the stock cams, another set of cams are almost definitely not going to be in the budget.
