Old 04-04-2011, 02:05 PM
Originally Posted by 92 SVX View Post
OH wow, if you had a topic on this I missed it I will have to look, curious what happened.
I will make a thread, I just don't have time to right now. I'm not 100% what's wrong yet but I know the engine's f***ed. Focusing on fixing it now more than finding out exactly what's wrong.
Old 04-04-2011, 02:14 PM
92 SVX 92 SVX is offline
ya understandable. I think I have headgasket that is slowly going most of the time I dont have any trouble but once in a while it will start getting hot and when I open the rad cap its low. Not too many reasons for it to get low.
Old 04-04-2011, 02:18 PM
It could be an innocent leak. Any smoke coming out the back ever?
Old 04-04-2011, 05:09 PM
No smoke ever. I dont need to fill it very often either running it every day maybe once a month or every 2 months. I replaced my rad cap a couple weeks ago and it seems to have taken care of things. I hope so.
The day I went down to your place I ended up filling the rad at a service station before I left tampa.
Old 04-10-2011, 04:47 PM
fun173's Avatar
fun173 fun173 is offline
#1 BRODAWG!
Used the mothers powerball headlight restoration kit. My headlights were not bad enough to need sanding but I just used the polish and they look much better!
Old 04-15-2011, 06:09 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Yesterday, I found that the ABS controller and its respective monster harness plug weigh about two pounds.
My basement weighs about two pounds more now.
Old 04-15-2011, 07:55 AM
XxMattrimxX's Avatar
XxMattrimxX XxMattrimxX is offline
I did this the day i bought her, and I will say it was worth it. Yesterday I washed her.... two hours later it rained.... today I will be waxing.....if it will stop raining.
Old 04-15-2011, 09:13 AM
Tomodachi Tomodachi is offline
Paid my road TAX here Japan today & maybe
install my S/S brake lines tomorrow if I can use the lift at the Auto Hobby Shop on base? Will take pictures? Can anyone suggest brake fluid? Thank you all you diehard SVX owners and happy drivers!!
Sincerely,
Tomodachi
Old 04-15-2011, 09:22 AM
Sincerely,
Tomodachi
Stainless Steel lines are a very nice upgrade to the SVX.
Do one wheel at a time, to make sure you get the routing right.
I always use a fully synthetic Valvoline DOT 3-4.
I am not sure what is available to you on the base.
Old 04-15-2011, 06:48 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
I cleaned and waxed the exterior and cleaned the entire interior and I also used some Crystal View headlight restore.
Check it out.
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 04-15-2011, 07:56 PM
Installed a new Ecutune Rom in my TCU, but ran out of daylight before I could get the TCU reinstalled in the car.
Old 04-15-2011, 08:01 PM
LetItSnow's Avatar
A lil' vac and shampoo work, and then I emptied the catch cans.
Let's just say I'm glad I didn't go for an AOS!
Old 04-15-2011, 10:16 PM
kinz kinz is offline
Oil change. Got a new air filter (fram). Had plans to wash but didn't happen.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black
92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white.
Old 04-16-2011, 07:48 AM
SVX_MY_BABY's Avatar
I was told by my mechanic that switching to synthetic fluid would ruin the seals.
Unless you are racing or driving down steep mountains at high speeds I don't think you will get DOT 3 regular fluid even close to the boiling point.
Peter
Old 04-16-2011, 08:29 AM
Valvoline DOT 3 & 4 Brake Fluid
Valvoline® DOT 3 & 4 Brake FluidFor all ABS, drum or disc brake systems requiring DOT 3 or DOT 4 fluid
Compatible with all braking systems requiring a DOT 3 or DOT 4 fluid
Mixes well with conventional fluids
High dry boiling point up to 480°F reduces the risk of fluid evaporation and possible brake failure
Low-moisture formula provides excellent vapor lock protection
Maximizes ABS performance
Ideal for hydraulic and disc brakes
Surpasses specifications SAE J1703, FMVSS No. 116 and DOT 4 Motor Vehicle Brake Fluid
Minimum wet boiling point is 311°F
