#106
Re: SVX Engine cooling "Again & Again"
Tony, excellent job so far. Concerning the flow meter, what is your budget in US$ for that?
The tank method might be useful... to a certain extent. As you said getting approx numbers is better than getting nothing. As for the coolant pipe clearance, do you think it will clear a stock manifold?
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
#107
Budget a couple of $100. This manifold is the same hight as the standard.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#108
Tom |
#109
This picture surely shows that we have a lot of space to do a Y system into the rad, just in case. As for the flow meter, I am searching and sending emails to potential suppliers. Since it is Sunday, I guess we should expect something by tomorrow... our time ![]()
#110
My friend with the buggy has tried changing the ECU from a Motec to EMS in an effort to solve the cooling problem as he beleived that the timing was out but it didn't solve the heating problem. I think he is at a point were he will pull the engine out and change to a different type. There is nothing he can do to keep it cool and now he is about to give up on the SVX engines.
Tony
#111
You and I should make an offer on his engines...his current price is a bit high though.
M |
#112
![]() What has he done to the cooling system on the engine.? What pump, and flow rate does it have? What was the modification that he did to the outlet piping? What is the radiator that it has.? What rev range does it run? Harvey.
#113
Just in case criticism hits the fan, for what it is worth, I will back you on this one. I am as you are, fully aware that it is easier to advise than do, but it is becoming obvious that the train has never been on track. The thread clearly shows a lack of any sort of logical approach in curing the problem. Basic rules covering testing have not been carried out. So far there is nothing but a confused set of trials, often two at a time. No proper conclusions have been established from work to date. Incoherent fiddling is not science. What stands out is that the cheap and simplest options, have not been tested. Even if not a complete success, these could prove valuable in providing definitive evidence and move things forward. There has been talk of flow testing. As I see it, this will only be of value if a figure for right and left sections can be established. From a mechanical slant, this would appear a very difficult proposition. The actual information required relates only to, --- is the flow to high or too low, on one side only, or throughout. This can be established by testing rather than measuring. First up, blank off the heater circuit at the pump, remove the thermostat, i.e. for increased flow. Note the results before and after. A means of measuring accurately any change in temperature will be valuable. However again, actual figures are not that important. As always, sticking neck out, Trevor. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
#114
I understand were you guys are coming from but I am the only guy that has a method to measure the return water temp and with in 3 day able to measure the head tempreture on each bank as well as return coolent from the bottom of the radiator.
As regards the buggy we have a race track on Steve farm and we measure how far the buggy gets before overheating. At this time I have been pushing him to measure return coolent temp but only now has he agreed that it might be an issue. What we do know from trials we have done todate. - Take out the thermstate as it overheats to soon otherwise. - Overheating occur from about 5,000 rpm up. Below this it isn't a problem. - If we are using a standard cross pipe ontop of the engine we have to return coolent to the pump through the heater pipe. This suggested the top pipe was a problem. - The orignal radiator was over 3 times bigger then ours then it was changed to a multipass unit. This change improved to distance before overheating. - We have tried a Craig water pump with the existing turbine removed and it was no good at all. - Of the current pump options the orginal was best. - Its not the ECU as we have tried two types, but both are having problems reading the cam timing at 6,000 rpm with the result that the engine is breaking up at high revs. What we don't know but will is how well the airflow and radiator are getting rid of the heat generated before returning to the engine. If I have forgot anything ask. What I will be doing hopfully this week end :- Fit dual temps to the heads. Drive down the road at 110kph on a straight flat road for 100k measure outside tempreture. Drive for 15 minutes in 6th then measure the temps on the three guages. Repeat in 5th, 4th and 3rd while still driving at 110kph. Graph the results, and I am guessing that as revs go up the left bank has a harder time getting flow due to the pressure restriction. If that is confirmed I will then change the top pipe over to the moded one (i have two of them) and re conduct the trail at the same outside air tempreture. This is long winded but I am getting somwhere, I spent two much on my race engine to assume that it won't overheat so I intend to stay on the issue till it is solved. Have a great day guys and I hope you are all healthy and well. Tony
#115
sounds like a solid plan. let us know how it goes
Tom |
#116
May I jump in here and just add some food for though......
-Loss coefficients of the coolant system in case? -LC's of the pump diffuser/case coolant inlets? -Relieve the case of micro bubbles at bores and vent to swirl pot(highly likely due to case passage design, compare 30/30r and porsche castings to EG casting ![]() Did not have this issue with the EG33 in the 96X2 prototype chassis, but then again the entire ME-RWD drivetrain in that car sat at about a 15 degree cant(motor low). Quote:
![]() Carry on with normal discussion ![]() |
#117
Or is it modded with the swollen middle? Or is it modded where they join on the right bank? The heater will always pass water, I would not say it shows a problem. As one end is to the top pipe, the other is to the inlet side of the pump. Then you have the Bypass pipe that does the same thing from the other end of the cross-over pipe. These types of sensors are not good for high speed operation, because of the reluctance of the unit, they can end up with a constant voltage, that can't be read. Thats why they have changed to the Hall Effect sensor for crank pick-ups, a more reliable signal at speed. Harvey.
#118
Harvey we are running the swollen cross over pipe now, when you say the hall effect type are better what cars use them and were would I get one. I was thinking of getting a sensor from a Porsche as you would think it could handle it. I think Tom made the point that the one on the crank is working at 12 times per rev and still reading okay but the cam is only read 1 time every 2 revs. Or have I got the bull by the tail instead of the horns?
Tony
#119
Tony, I have contacted two companies for you, I dunno if their products are applicable to car engines, pls check them out:
Liquid Controls Pathfinder Instruments I am still waiting for their replies ![]()
#120
Bubbles/air/turbulence as suggested, constitutes a very likely problem worthy of attention.
