#1201
good to hear! how is it running on lower boost? does it feel any faster? I started my new job(yea i am in the real world now) so i have been out of the loop
phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#1202
it is running great... If I could keep traction I would be even more pleased
![]() ![]() Tom |
#1203
Tom I like the way this looks I will do mine the same, as mine won't be the daily drive I think doing away with the AC is a great plan.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#1204
Would it possible to relocate the p/s pump down and use that spot for the alternator? A remote reservoir adapted to it wouldn't be too difficult.
#1205
now thats an idead
![]() Tom |
#1206
You do know that XT6's had an electric steering pump located on the firewall??
#1207
To be honest... The fabrication required to fit the alt on the pass side... keep the A/c where it is and converting to an electric PS pump is not worth the effort IMHO. I had hard enough time mounting the alt where it is... it would be a nightmare to mount on a completely custom bracket
Tom |
#1208
what does the electronic doodad on the side of the power steering pump do?
#1209
and what are the various harness plugs on the xt pump for?
#1210
In the top right photo;
- The wire at the far side is for the fluid pre-heater, to warm the fluid on cold mornings. - The blue wire and black cylinder at the right side is the temperature sender, to allow the controller to activate the pre-heater if needed. - At the cap, the obvious one is a ground, power is supplied to the two black caps on the cap end.
#1211
The "controller" is a stand alone device for the power steering pump? Is it fair to assume the pump works fine without the heater and temp sender hooked up?
Can you take a picture of one installed in an xt6? I'd be curious to see their mounting.
#1213
![]() The controller is a seperate box to the side, and then there is a seperate computer. Basically the pump will provide "Full Power Steering" if you add 12v to the connectors on the cap. The temp sender and pre-heater are not necessary but steering would be stiff till the fluid warms up. The computer to control the speed of the pump takes input from the ECU, motion indicator on the steering wheel, temp sender, speed sensor... maybe more. I've heard that jeepers use them on their off road rigs, not sure if they just supply 12v or if the rig up some sort of controller.
#1214
I believe our pressure control circuit is on our racks; I don't think we would need to control the output of the pump if we were to use it.
#1215
