#121
Mr. Dynomatt,
By any chance did you adjust the DMS coil overs down to their lowest adjustment to see what the minimum ground clearance is?
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$ |
#122
I didn't I'm sorry, because it's of no interest to me.
However, the fronts are 83mm above the start of the threaded section, so potentially, you can lower the front by 83mm (3.3 inches) and the rear is up 45mm from the base of the spring platform, meaning it can go down bout 1.5 inches from there. DMS will do short stroked versions for street cars. Ours, as ground clearance was a mandatory requirement, have been lengthened and it shows. Matt |
#123
Road units.
Matt do you know what the spring rates are on the ones that Tony got?
#124
no, default is in the locked position, so you will either need to rig it so its always open or just extend the shift linkage like you really should... If you have the stock shifter, I can extend the pieces I have here and send them to you... but it will have to wait until I get my shop all settle in and I have a welder and electric for it. Which could take 3 weeks or so
Tom |
#125
oh and that is Huck's rear shifter mount if I remember correctly. I have used a couple methods of doing them but my 6mt silver has the stock rear mount with a custom bracket
Tom |
#126
However, they are valved differently. M |
#127
Matt were are you up to with the exhaust have you pounched out the cats yet. Given that they don't test our emmisions in Australia I was think of doing mine to let the poor thing breathe better.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#128
G'day Tony,
As discussed, new exhaust went on today. Rallying is pretty hard on exhausts so they are virtually disposable. I got a pretty basic system...twin to just behind the gearbox, where there's a y-pipe followed by an expansion chamber, then a resonater, and a muffler at the end. Just out one side, rather than both. No idea what it sounds like...should have it running tomorrow all going well. Tom, regarding the reverse lockout detent, it seems that the default position on mine is open...hence I can select reverse no problems with the shifter completely disconnected...the risk is the run from 5th to 6th and accidentally selecting reverse. I was talking to a guy who adapted a 5 speed shifter assembly the other day. He modified it to have the reverse lockout function, and as the linkages are longer, I'm reckoning that might be an option for me. Failing that, I can cut out more of the transmission tunnel, and just use the factory setup. I test fitted it tonight, and it doesn't seem too far away. Matt |
#129
good luck... It is a long reach to get to the stock unit without extending it
Tom |
#130
Harvey I checked with DMS today and Matt & my struts are exactly the same Jamie just suggested that i run them set softer. Tried the car on dirt last night and it work brilliant it didn't look like bottoming out. The variable rate springs mean the vibration getting to the car on dirt as it did with the old struts. I think Matt will be happy.
Tony
#131
#132
So time is running out...
My first rally is on this Saturday (weather permitting) and I've got lots to do. I spent the weekend on what seems like a whole lot of nothing...but I didn't stop, so I'm not sure what I ended up doing. I know I did a bit of stuff that would make you guys cringe...like drilling two 15mm holes through a perfectly straight bonnet. Like drilling holes to mount the mudflaps to the rear. It starts and runs perfectly now though. I was missing the starter signal to the ECU, and that was enough to completely confuse its starting sequence. Now she starts and idles smoothly each time. On Friday I got the brake lines remade since the ABS has been removed. Also had the sump guard and gearbox mounts finalised. Tom, I'll have to take some photos of the car with the new gearbox mount. He's taken a similar path to you guys for the rear part (ie adapted the standard SVX rear mount) but has used a standard WRX front two parts. He's then welded strong tags off the chassis rails to hang the standard WRX mount. Looks good. I'm just waiting on a few more bits that are due to arrive today, and I should be taking it for a drive tonight. Also have the mandatory safety inspection tonight to see if it will pass...here's hoping. Matt |
#133
Go get 'um Matt!
-Bill
#134
um... what are u doing for shift linkage??
Tom |
#135
Tom,
I test fitted the shifter (unmodified) last night. It sits about 1-2 inches too far away from me. So I suspect I'll do what you've done. Do you need to extend the cable like you did in the photo? Or can it stretch...and if it can stretch, how far will it stretch to avoid extending the cable? Matt |
