#1381
Re: SVX Engine cooling "Again & Again"
everyone only thinks they are good size holes, I posted a photo years back that shows when you look in the hole the linner is blocking the hole. In other words bad flow, even if you removed the top pipe the flow through the engine would not increase much because of this restriction. You can do what you like on the top pipe and nothing will change. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#1382
I'm not convinced of your theory because viewing from inside and outside, the exit holes and the feed to the exit holes do look good and are 29mm. They would have to loose almost 50% of their flow rate capacity before the 30 mm cross pipe exit is less of a restriction and even though it's not an ideal flow path to those, I can't see that happening. You can see one of the outlets here from inside and outside the engine: |
#1383
You can't even fit you little finger in the bottom of the hole, it would lose more then 50% of the flow of that hole. I did measure the pressure loss between the jacket around the linner and the down stream of this port and it was substantial. From memory it had the highest single restriction of any part in the engine block.
Tony
#1384
Also Bazza I seem to remember measuring the pressure loss from the outlet of the left bank (the 29mm hole) to the end of the top cross pipe at the top of the radiator and the loss at 200l per minute was stuff all maybe 2 psi.
Tony
#1386
Good stuff as it relates to the different characteristics of the radiators you used! Thanks for the link to your web site, it's now bookmarked in my "SVX Racing" folder. It would be great if your site could serve as the data repository for all the testing that you, Tony, and Tom J. have performed to date. Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 10-15-2012 at 10:42 AM. |
#1387
Bazza,
If you are going to do some more testing on the flows this week end you can borrow my guages if you want. Also if I understand you correctly you want to see how much coolant can flow through the standard top pipe as a stand alone test. Is that correct? Tony
#1388
* Crossover flow and pressure drop * Engine block flow and pressures * 2 and 3 bypass lines flow and pressure drop * Thermostat flow and pressure drop Phase two of my testing will commence: * Hot engine open system flow rate at various RPM with no radiator * Add radiator to the hot engine system (open) and test various pressure locations at various rpm I would not say no to borrowing some decent gauges Also one of the major drivers for this is my sanity - the fact that this issue has never occurred in the STI's I just cannot get my head around having modified the sh!t out of STI's and their engines for nearly 10 years and flogged them to near death in all sorts of racing, never ever seeing any overheating issues. My friend who has the EG33/GT40 turbo setup worked at STI docklands as foreman (biggest Subaru owned STI workshop in Aus) and he agrees that it doesn't make sense for us EJ2X to EG33 converts and is very interested in what I come up with. Funnily enough he has the overheating issue already and thanks to what you found with the cover has saved him also several months / years of pain which he is most grateful. Last edited by bazza; 10-16-2012 at 07:32 AM. |
#1389
Bazza happy to loan you the guages. In your work you may have to do like I did and set up a proper SVX pump and drive it with a electric motor as I am not sure you are going to correctly duplicate the behaviour of the svx cooling system unless you do that.
THe other thing worth doing is using clear pipe feeding the pump then you can see when the pump is cavitating because the water goes milky. What KW is your pool pump? Also depending on have far in the testing you want to still use you pool pump we will need to get a flow chart for the pump. Every centrifugal pump has a maxium pressure it can pump up to. If that pressure is exceeded the pump drops flow. I have a backing plate so you can bolt a SVX pump to the front with out the engine but you will need drive it with a electric motor. Tony
#1390
Bazza and I spoke today and he made a point that the STI's never over heat so why. I think we need to buy a STI water pump and run some tests to compare the pump performance curves.
Tony
#1391
I've got about 3 sitting in the shed haha. You actually cannot tell them apart from the SVX pump without comparing the pulley offset. Last edited by bazza; 10-19-2012 at 04:42 AM. |
#1392
Is there pulley larger or smaller then the SVX one?
#1393
Bazza the STI that you say runs cool do they have down flow radiator or cross flow? My exliberty had cross flow.
#1394
It's wider as the EG33 has a wider timing belt. Diameter is the same.
#1395
