Help
hello i have a 92 svx and when its wet out the front tires will spin then the back makes like a grinding noise and kicks in i already have the adative in from gmdealer so what could it beplease help me to solve my problem i really like this car
Trans problems
Transfer clutches or worse. Sorry.....
Todd
Down to none |
Re: Trans problems
Does it shudder when driving sometimes? Like when you give it gas and let off? Mine did that a day after I got it and then a few days later when I was having it checked out I found out my rear tires wernt working. Rear berings and tranfer clutches went. Its still in the shop... I hope to have it back tomorrow.
I hope your car does not suffer the same fate as mine did. Its expensive.
Green 1994 SVX LSi - Totaled by a plow. RIP Bordeaux Pearl 1994 SVX LSi - 182k Last edited by Wiz; 10-27-2003 at 06:19 PM. |
i just replaced rear bearings a few monthes ago the rear wheels r working cause u can feel them move in the rain i was wondering if any one thinks that it could be the bushing in the rear sway bar
If it's making a grinding noise, it won't a sway bar bushing problem. If a bolt holding the sway bar bushings has fallen off, it causes more of a clunk sound. You should be able to easily see the sway bars if you look underneath the car. A more common sway bar bushing problem is that they will make a creaking noice going over a speed bump. A little lube will mkae things better that (just make sure they put all the bolts in properly).
