Trailing Link Bushing
Does anyone have an aftermarket poly bushing for the SVX'S rear traling arm link? The bushing which attaches to the rear subframe, NOT the bushing that attaches to the rear housing.
I'd prefer to get these specific bushings rather than purchase the entire link for $110 each! |
Re: Trailing Link Bushing
Either strongflex or turn in concepts has that bushing, I just forget which is which. Check their websites:
http://www.strongflex.eu/en/subaru-svx-91-97_256 http://turninconcepts.com/product_in...oducts_id=1162
Strongflex has the bushing. You can use the TiC bushing if you modify it and the crush tube. I have the whole TiC rear bushing set up.
'92 SVX LS Pearl White - 6mt |
Thanks guys, is the strongflex direct OEM replacement? I know the tic bushing needs to be modified to accomodate the stock bolt...
