Old 09-05-2002, 07:11 PM
svxeno
Headlamp care
I just had my headlamps cleaned of the cataracts. Any suggestions to help preserve my newly gained cleanliness and visibility?
Randy \()-()/ ii
Old 09-05-2002, 07:36 PM
Yeah, don't use your headlights....ever!
Well keeping it out of the sun is probably the best thing you can do. The less heat the better.
Old 09-05-2002, 07:51 PM
lee lee is offline
I think driving with a blue car cover on would help - they say blue cuts out some of the Sun's damaging rays - just cut holes in it for the windshield like a "ghost" on halloween.
edit
Seriously, look here (near bottom of page)
http://www.subaruparts.com/catalog/?section=176
Old 09-07-2002, 06:55 PM
svxeno
The third suggestion I can take. The first two..uh...hmmm..i dunno
Thanks
Randy ii
Old 09-08-2002, 07:02 PM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
Along these lines, HOW did you clean them or have em cleaned? Mine are all yellowed and I want to clean them before I get my HID upgrade.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 09-08-2002, 07:39 PM
svxeno
-mike
Mine were pretty bad. I had a local shop for $20 use an air powered wheel and 3m plastic cleaner to improve them to about 90%. This will suffice for now. If you search "Seraph" (Lwin) has a very detailed explaination of how to thoughly clean them inside and out. His results looked near unbelievably good. This is in my future when there is more time.
Good luck.
Randy ii
Old 09-08-2002, 09:42 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Good luck.
Randy ii
Go there:
http://www.svxworldnetwork.org/
Then click on howto, then cleaning your headlight. I have more to upload there. I am just real busy
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 09-08-2002, 09:56 PM
Another product that has been used with great success is Eagle brand small scratch remover. It does an incredable job using it on a rag and after a very short time they are completly clean and no yellow remains. You might try it first. I have used it and it works wonders.
Here is the link to where it can be purchased. Good luck.
http://www.eagleone.com/products/pro...02&itemid=1056
Old 09-09-2002, 10:51 AM
Ca$h
Chrome polish also works great. A bit more bit in it.
- Ca$h
Old 09-09-2002, 12:32 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
I use the Novus 3-stage procedure. I think most can attest to its effectiveness.
The #3 is a deep scratch remover
#2 is a fine scratch remover, and
#1 is a clean and shine protectant.
First clean the lens with the clean and shine, then, using lots o' #3 and some elbow grease, clean the lens in a circular motion, rubbing hard and making sure the surface is always "wet" with the medium. Let it dry to a haze, then, buff it off with a clean terry rag. Do the same with the #2 product. Then, spray on the clean and shine, wipe throroughly, then buff with a clean cloth. You'll be amazed at the results.
You can also do the above with a power buffer if you're so inclined.
All three of the compounds are available at http://www.jcwhitney.com Just do a search on Novus -- it's available in the 3-piece kit for around 15 bucks. Since it's forumulated for plastic, it's safer to use than, say, chrome polish or rubbing compounds, which are initially effective, but potentially harmful.
Randy Johnson
Mike Davis -- at Reading VI
Old 09-09-2002, 04:48 PM
ehyde111
edit
ANy chance you might be able to spray them with ?something? and get the blackout look?
Old 09-09-2002, 05:02 PM
Seraph's Avatar
Don't you want to see the road?
Current SVX: • NONE
Old 09-09-2002, 06:32 PM
ehyde111
That's funny. ANyway, I said something -- I know they can't be painted, but I thought I had read something similar on another group, but not sure exactly what.
Old 09-09-2002, 06:39 PM
Seraph's Avatar
You can spray them. There is a smoke spray which can make it look like the whole thing is black out.
Current SVX: • NONE
Old 09-10-2002, 12:07 PM
Ca$h
He said something LIKE blackout. You don't have to be a dick about it. I'm assuming he means some sort of clear protectant spray, similar to black out stuff only clear.
- Ca$h
