more 5spd swap q's
do i have to change to a legacy starter or will the svx one work with the new setup
1991 xt6 eg33? 1993 gc track car |
Jeff,
You have to use a manual starter, the auto's nose is different....
crap
it said i had to make my psot longer so i did
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
...but I paid like $17 for mine used and they're easy to come by
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
just to answer this, i'm currently sans drivers license so i have to be patient, or very careful on trips to the junk yard.
update have starter, pedal cluster removial is a pain in the ass!!
Tom |
how do i get the bolt that is above the steering column out?
1991 xt6 eg33? 1993 gc track car Last edited by jeffast; 09-19-2007 at 07:05 PM. |
a ratcheting 12mm wrench is what I use... Also I suggest taking the column out
Tom |
ok, i don't have racheting wrenches, how does one go about pulling (arg) the column
Just unbolt it (the column)from the dash so it can drop down out of the way so you can get to that bolt...
Take out the drivers seat if you haven't already.
i did it with the column in and I assure you it will take 10 times longer.
not what i wanted to hear but thanks for the advice guess i'll pull the column
