Argh, these remotes...
...they really are the biggest pieces of crap. Mine don't even get used a lot. My wife bought me a new remote les than five years ago. In that time I've driven my car about 13k miles. So most of the time the remote hangs on the hook, unused.
I just had to solder the antenna wire back onto the antenna in the remote. Before I did, the range was a maximum of about 10ft. Sometimes it didn't even work. The range is better, but upon putting it back together I noticed that the corners are cracking, which means the case won't stay together much longer. These things really do suck. Does anybody know if the remotes from another Subaru model work? Does anybody know who manufactures these things? Maybe another car from another namplate uses a similar system with compatible remotes that don't fall apart.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 2005 RX-8 Grand Touring 2005 Outback 2002 Mercedes-Benz E320 wagon END OF LINE Last edited by Mr. Pockets; 06-27-2006 at 04:58 PM. |
Actually, it looks like Jaguar might have used the same system. Well that explains that - at least the Jaguar influence stops at the remote.
www.keylessride.com That site sells remotes that are apparently compatible. For $40 I think I'll give it a try. They may not say 'SVX' on them, but that's a small price to pay if they work.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 2005 RX-8 Grand Touring 2005 Outback 2002 Mercedes-Benz E320 wagon END OF LINE |
You're totally right. I hate htem. I want to get an aftermarket remote system but I haven't been able to find one with the 'class' that hte SVX deserves. They either feel cheap and generic or cheap and boy racerish. :\
Oh, I don't want to install an aftermarket keyless system. I just want to replace the remote. I'll have to order the one I posted about above and let everybody know how it works out.
If I press the remote against my forehead, I get just enough distance from it where I can't touch the car without leaning in.
Worse remote.... evah!!111!!1
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
The distance is identical to OEM. No improvement besides the looks.
I have a pair of the keylessride remotes and they work perfectly.
They are smaller, thinner and seem to be so much better constructed and sturdier than the stock remote, using a better grade of plastic. The neoprene gasket that goes around the perimeter between the two halves make it much more water resistant as well. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
my wifey bought me a "keyless ride" remote that is supposed to be compatible
I cursed her as a philistine and immediately cast the remote into a desk drawer where it has remained for the last 2 years. No idea if it works or not but I guess it should? In the meantime stevebsy hooked me up with a sweet svx remote that was in pretty good condition ![]()
It's the construction of the remote that pisses me off. It's a cheap piece of crap.
Mine has fallen apart numerous times this year because of the case corners being worn down. I think I might get a few of the $39 aftermarket ones to see how they do. Doug
i have the opposite problem. three working svx remotes with a bad security system.
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty ![]() ![]() 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 ![]() 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
I never lock mine with the key....you push the lock down inside and when you close the door you shut the door with the handle up....I've always done that with all my subaru's.
