all interior lights dont work
my clock/maplights/domelight/gaugecluster/climat control unit lights all stopped working
what would cause that
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
Re: all interior lights dont work
Most obvious is check the fuse .Both locations
did that all fuse fine unles there' a 3rd location,
even the power to the deck cut out
Door lock timer possibly.
Does the car still start and run? |
there's a door lock timer?
ye car still runs and outer lights still work
Check the lighter socket fuse.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
I'd go through all the fuses pulling them one by one. If the fuse isn't blow then you have a bigger problem
It might be worthwhile to check out the wiring to the sun visors. Many odd problems such as these have been a result of broken or frayed wires.
Do a search starting HERE .
btw chalk up rear defroster to that list of stuff that doesnt work
Did you go through each fuse?
^^ That seems wasteful. Apologies.
If the lighter works, the visor lamps shouldn't be used as a diagnosis for this problem; they're unrelated this far down the line. Does your rear wiper work? If not, I'd be with Nate on the time control unit. Believe it - your interior lights, rear defroster, and rear wiper are all tied into it.
Disclaimer: The above post is on the internet. Last edited by LetItSnow; 11-30-2011 at 06:47 AM. |
Sorry about the link. I just typed sun visor wires into the regular search box and got a listing of various electrical scenarios.
sounds like what mine did a while ago. Turned out it was a bad time control unit. its located behind the glovebox.
that could explain the burning electrical smell that came through when i turned the vents on.... does anyone have a pic of what it looks like and/or have an extra part?
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... Last edited by Gamesy; 11-30-2011 at 12:16 PM. |
