Old 05-18-2007, 11:30 PM
kcpaz kcpaz is offline
Torque specs...
I'm looking for the torque specs for the upper and lower intake manifolds, the throttle body, water x-over, and thermostat housing. Anyone know these or know where I can look them up?
Old 05-20-2007, 06:32 PM
I would look in the How-To Documents. I did and found this page with some of them. I hope it helps.
Old 05-20-2007, 10:12 PM
Thanks a bunch. That page was full of all kinds of useful specs.
Old 05-20-2007, 11:15 PM
It is amazing what you can find in that little section.
Old 05-21-2007, 07:18 AM
Originally Posted by kcpaz
I'm looking for the torque specs for the upper and lower intake manifolds, 17-20 foot/pounds
the throttle body, Could not find it in the book this morning, but I believe it's 17-20 foot/pounds
water x-over, 4.3-5.1 foot/pounds
and thermostat housing. 4.3-5.1 foot/pounds
Torque converter to flex plate; 17-20ft/lb
Bell housing nuts/bolts; 34-40 ft/lb
Drive shaft flange; 17-24 ft/lb
Rear diff (2) long and (4) short bolts; 94-116 ft/lb
Driveshaft carrier bearing bolts; 35-42 ft/lb
15 minute/$15 mod; 39-48 ft/lb
2 rear diff mount nuts; 45-56 ft/lb
6 trans crossmember bolts; 40-61 ft/lb
3 nuts for trans mount; 20-35 ft/lb
Spark plugs; 14-22 ft/lb
All cam belt sprockets/pulleys; 14-22 ft/lb
The 2 bolts on the timing belt adjuster; 17-20 ft/lb
Old 05-21-2007, 09:22 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Got the service manual hosted online at http://serial.cc/ if you want to check it out. You hsould be able to find the specs there easily.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
