Oh no! Not another radiator post!
Hello everyone!
This is my first post to the forum. I have been aware of the SVXWN for a while (thank you for the excellent info) and finally joined this year. I finally decided to replace my Calsonic radiator with one from PWR, ![]() ![]() Everything was going fine (I knew about the bottom rad hose inlet/fan shroud problem and the overflow pipe being too small) but I was not prepared to find out that the transmission hose barb to be too small. ![]() ![]() Does anyone here have any information on when Subaru changed this parameter and/or why? Thank you in advance. Chris 1992 Liquid Silver with 240,000 original miles |
I'm confused: what are the hose internal diameters?
What hose is too big or too small & where?
![]() Cheers!
' 92 SVX @ 185K ' 91 420SEL @ 223K! ' 88 420SEL I. @ 178K (what a buy!) ' 87 F250 @ 180K ' 93 ZX-11D @ 29K ' 93 SC400 @ 93K 2001 Valkyrie Interstate @ 6.6K (Brynhild) Y2K NightHawk 250 @ 1,500 miles ' 88 420SEL II. @ 208K '85 F150 @ 135K |
Clarification (I hope!)
The hose barbs for the PWR transmission cooler section came with 7.5mm OD barbs. The OEM Calsonic rad uses 10mm OD barbs. I am planning on using the transmission cooler, so I need the 10mm barbs. (my transmission fluid hose has an ID of 10mm) My question arises from my conversation with PWR. They have sold a lot of these radiators for SVXs without anyone having a problem with the size of the transmission hose barbs. They are looking into the problem but I was wondering if it was a PWR production mistake or if Subaru did make a change in the transmission fluid line feed (10mm to 7.5mm) in the production lifetime of the car? So, what size transmission fluid hose (ID) is being used on your SVX? BTW: The radiator hoses fit just fine. ________________ 1992 LS-L Liquid Silver with 240,000 original miles |
Problem solved
Just talked with Brandon @ PWR.
Looks like they they had a few built with the wrong size fittings. ![]() They are sending replacements! ![]() If you plan on buying one of these radiators from PWR, you might want them to check and make sure that it has the correct size transmission cooler fitting. Chris __________ 1992 LS-L Liquid Silver with 240,000 original miles |
