Old 11-23-2008, 12:54 PM
mikeytown2 mikeytown2 is offline
main rear seak broken, stuck in Sacremento
any ideas how to fix, advice, stc stc
helplfor quick , temporay repair
Desparate, reply asap !
that's main rear seal broken !!
What to do???
help?
Old 11-23-2008, 01:00 PM
Re: main rear seak broken, stuck in Sacremento
that's rear main seal leaks about 1 quart in 5 min.
Old 11-23-2008, 02:15 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
The's only's ways to get's that's rear main seal fixed is to pull the engine OR trans (trans being the easier route). Either way, the two have to be seperated.
Dustin
-Dustin
Old 11-23-2008, 03:48 PM
I think I will have to junk it here in sacremento? not much of a choice--will have to wait till junkyards are open tomorrow; one last night in my svx or try to sell for parts; but don't think it will drive very far.
I need to get to LA, so anyone going that way???
Old 11-23-2008, 03:51 PM
Wikedjuggalo's Avatar
Rebuilding
What do you mean rear main seal broke? You sure its that? Not sure what that miracle in a can, can do for ya but **** worth a try.
Old 11-23-2008, 03:58 PM
use some oil treatment slick 50, marvels mystery oil, Lucas, something to try to add extra lube power if its losing oil that bad. maybe the extra treated oil will keep bearing okay with no oil pressure.
Old 11-23-2008, 04:53 PM
its leaking about a quart of oil / 5 minutes.
What else would it be ?
Old 11-23-2008, 05:14 PM
Rebuilding
Did you puncher your oil pan?
Old 11-23-2008, 07:29 PM
Hondasucks's Avatar
Subaru Technician
Would be easier to have a shop fix it than to buy a new car! Would be ~500 bucks or so, not sure what the rate is down there, at my work we charge 6 hours to do an access cover, which is just as much work as a rear main.
You could also perhaps rig up some sort of catch can with a washer pump to pump the oil back into the engine, I've seen that done on an old Dodge truck, would at least get you back to LA... If you get me a phone number, there are some USMB members in Sacramento that could probably help you out.
1986 VW Jetta
Old 11-23-2008, 07:49 PM
Hey so that was my parents posting it for me.
I made it to a friends of a friends house east on I-80 about 20min from I-5. I can drive about 10 min before the oil light comes on, so I'm guessing 1 qt of oil every 3 min or so. I had to pull over twice to refill the oil for a 20 mile trip. It's smoking like crazy from the oil hitting the exhaust. It leaks only when its on and only when the car's hot. A cold start and it doesn't leak for about 30 seconds. As far as I know, there has been no engine damage. Most likely going to do a fire sale on craigslist.
If anyone wants to buy/help here's my #
213-268-0990
I'm 99% sure that its the rear main seal near the top. Anyone going to LA?
Old 11-23-2008, 08:43 PM
Old 11-23-2008, 08:48 PM
Rebuilding
If its coming from the back of the engine then its rear main seal. I know mine leaked but no were as bad. Pretty amazed it is just gone.
Old 11-23-2008, 10:13 PM
svxpert svxpert is offline
<<I'm 99% sure that its the rear main seal near the top. >>
what are you talking about by "top"? i think its the separator plate. unless you damaged the rear main or someone put it in to far, no way that would leak that fast. either way, you have to get the engine and tranny apart from each other.
Old 11-24-2008, 08:27 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Check out www.uship.com to see if you can get it shipped back to you home. I'll schedule a dirt nap for ya (or have Earl the enforcer do it) if you junk an SVX over a sealJK. It really doesn't sound like the rear main to me simply because you shouldn't get that much out of it even if you put the car together without one. At the very least sell it to an SVXer out there for your bus ticket home.
Old 11-24-2008, 12:51 PM
Leaving the car with the friend to sell. Here is the craigslist ad
http://sacramento.craigslist.org/cto/932430352.html
Renting a car for $70 and going to LA.
Thanks everyone its been a great 7 years with my car.
