Old 06-20-2008, 03:34 AM
mrsmith mrsmith is offline
Rumbling?
Only had the car for a couple weeks and there seems to be a wining/moaning noise comeing from the rear? sounds like someting winding up! same in every gear just gets faster? apart fro that she seems quite good.. any ideas what this could be? thanks
Old 06-20-2008, 03:57 AM
Re: Rumbling?
To start with, that post should have been in the technical section.
Your case should be a bearings issue. You should check your rear wheel bearings.
Old 06-20-2008, 05:28 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Re: Rumbling?
My first thought would be bearing. Other than that, rear diff (if you have awd), or binding.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 06-20-2008, 08:26 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Re: Rumbling?
I would suspect nearly 99.999% that it is a bearing issue.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 07-19-2008, 12:13 AM
Re: Rumbling?
ahh haa wheel bearing it was!! thankyou
Old 07-19-2008, 12:59 PM
kwren's Avatar
kwren kwren is offline
Re: Rumbling?
This is the technical section
