Old 10-19-2013, 05:11 PM
davew833 davew833 is offline
Timing Belt Replacement Dilemma...
My 94 LS has about 93k miles. I mis-remembered the timing belt replacement interval as being 90-100k miles, so I decided to replace it, figuring it's probably the original 20-year-old belt. In the process of taking apart the front of the engine, I find pieces of an old shredded timing belt. I get down further and find a Subaru factory timing belt with a date code of 4-05 in excellent condition. So assuming the belt has been replaced at least once, I've got until 120k until it should need to be replaced-- that's >25k miles, BUT that belt is going on 9 years old. Should I replace or not replace the T-belt?
I suppose regardless I'll do the cam seals since they are leaking, so the labor's not a total loss...
davew833@yahoo.com
Former 6-time SVX owner
Old 10-19-2013, 07:53 PM
Re: Timing Belt Replacement Dilemma...
Because the belt is that old, I would replace it even though it does not have the total miles used for service. I would replace the water pump as well and the other things done at the same time. Good luck with the project.
Old 10-21-2013, 12:50 PM
make sure you clean out all of the old belt remnants. have a customer that needs a motor because his ps belt broke on vacation and the shop that put a new one on didn't retrieve the remnants. worked itself into the oil pump through the seal and wiped out the whole motor.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
