Fixed my stumbling idle- seafoamed the SVX today
Since everyone loves these videos, let's start with the video:
http://svx.northursalia.com/photos/seafoam.wmv I had a rough idle that bounced across about 500rpm, regardless of cold or hot. Cleaning the MAF helped a little, but not much, so I was going to do the usual tuneup items (I will anyway) and figured I'd give this a try. I gotta tell you, just doing this is enough fun to justify trying this, and the results just made the fun that much sweeter. One of my neighbors hates me anyway, and some guy driving by thought it was a hoot to watch ![]() The car idles much smoother, and is more responsive than I thought would be possible with such little time spent. I've had the professional BG treatments done on my Imprezas in the past, and while I imagine this was likely the dirtiest engine in my stable and a contributing factor to the change, I'd rather Seafoam in my driveway than pay for a BG treatment. 1/3 in the tank, 1/3 in the oil, 1/3 down the intake, and I've been driving around grinning like an idiot first at the smokeshow and now in the change in the car. Best $10 and 10 minutes I think I've ever spent on a car ![]() |
Re: Fixed my stumbling idle- seafoamed the SVX today
Forgot to add, I put the Seafoam into the intake via this vacuum nipple:
![]() Goes right to the throttle body and into the intake runners. |
Well done. I've had a bottle for a while but wasn't sure where the best place was to get it into the intake, now I know.
I'll probably wait until spring, that kind of a smoke cloud should discourage the black flies for at least a few hours. |
They're vicious down here- I'm pretty sure the buggers show up on radar
Any idea if this gets the seafoam to the AACV? I have long suspected that it is clogged. While I like the idea of cleaning my intake, this procedure always scared the crap out of me.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
That is exactly where I added it to my car, just use long enough hose and let the vac suck the stuff right out of the can.
I just put a funnel up at the other end of that silicone hose and poured slowly- as long as you understand to not either dump full bore or bury the hose in the can, the process was not scary at all.
I'll check the manuals and see if the AACV gets hit or not. Back in a bit with an answer hopefully ![]() |
So the answer is no, this will not clean the AACV when used at that location. However, you can still do so fairly easily. If you pull the vacuum line off of the driver side of the air inlet attached directly to the throttle bodies, this line goes right through the AACV, and then comes back up directly opposite where I was putting the seafoam in. Save a little bit and pass it through here and you'll be good. Hell, you can put it straight in here if you like instead, as it will end up in the same place.
I am curious to everyones take on using Seafoam on an svx engine.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
Kind of a sidenote...but that engine does not look like it belongs in an SVX. It is certainly an EG33, but I noticed a couple differences. There is no barb coming out of the driver side intake stack. And the waterpipe is on in a different direction. The upper radiator pipe should exit over the timing cover, not the side of the bellhousing. Does this engine look like it's going in a plane?
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
As a additional comment if your needing to use the stuff more often then once a year or 2, or 3 there might be a physical problem that you need to address. Unless the car sits for a very long length of time or who ever drives it only putts around like the little old lady. Last edited by 92 SVX; 01-16-2011 at 10:31 PM. |
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
I think it is modified for a VW swap. I'm glad to hear that the seafoam made a difference I think I will try it this summer.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Updated the pic with part of one gratuitously stolen from 92 SVX that was posted in another thread
