Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 03-30-2015, 06:56 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
Who's Racing Their SVX?
Who is currently racing their SVX? Autocross? Drag racing? Track events? SCCA races? Who is doing what out there these days? I don't hear much any more about actually running a SVX in a competitive event.
So, let's see some posts on what you are doing with the SVX!
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 03-31-2015, 07:10 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: Who's Racing Their SVX?
PPIR has been running bi-weekly time-attack/drift events, and I took my SVX once while in the middle of my suspension upgrade on the BMW, otherwise I've just been drifting.
I'd like to figure out the infamous cooling issue before taking out my SVX to any open track days.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 04-03-2015, 04:39 PM
Harry,
the only people on The East Coast that I know of that are Hill Climbing, AutoCrossing and Track Days are Elezar (radarwhiz) and Bill (SVXRide)
Tom & Melissa are temporarrily sidelined by delays and emission issues.
Is anyone doing anything that is actual sanctioned racing?!
Old 04-04-2015, 03:41 PM
solodon solodon is offline
Went to a BMW ice event in Wisconsin in Feb. Solo's are just around the corner here in Indiana. Will be attending those.
Old 04-05-2015, 10:42 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Represent! 😎
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-05-2015, 10:51 AM
Originally Posted by SVXRide View Post
Represent! ��
Bill
Perhaps you can expand on that, Bill.
AutoCross, Hill Climb, Track Days, etc??
Old 04-07-2015, 03:42 PM
SoobCrazy SoobCrazy is offline
SVX n00b
I autocrossed my SVX once. It had great low end torque, but on short, tight courses the LSi speed sensitive steering was terrible. The second turn in a chicane was met with zero assist pressure.
Also, the sunroof equipped roof is too low for my 6'1" frame with a helment on. I had to run with the roof open and my head cocked to the side.
I prefer to race my WRX.
Old 04-07-2015, 06:03 PM
radarwhiz's Avatar
Fairmont State University
Oops, didn't see this till just now.........
But you all already know what I do
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 04-07-2015, 06:45 PM
But to be clear, AutoCrossing, The Hill Climb, Track Days.
Elezar actually READS the rulebook and , what is the PC way to say what he does...
Busts my Ball Bearings to comply with the rules.
I on the other hand prefer the way the Greats "worked" the NASCAR rules in the 60s & 70s!
"Yesserie, Bob, thats a 4"bore, here use MY steel rule, heh, heh, heh."
Old 04-07-2015, 07:29 PM
radarwhiz's Avatar
That's just the difference between a driver and a mechanic.
Your pride is in the machine you build.
Mine is in perfecting my driving skill and testing said skill against other drivers, and that requires an equal playing field
Elazar
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 04-07-2015, 07:37 PM
That's just the difference between a driver and a mechanic/engineer/master fabricator/ CAR GOD!!!!!.Your pride is in the machine you build.
What is an equal playing field?!?!
Old 04-07-2015, 07:49 PM
radarwhiz's Avatar
That Rulebook
Elazar
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 05-02-2015, 01:44 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Smile Re: Who's Racing Their SVX?
Someone here in New Zealand has gone to a lot of trouble - but wow they have done a great job....
http://www.trademe.co.nz/motors/spec...-879936612.htm
Steve
Old 05-02-2015, 02:35 PM
That car makes my pants shorter!
Old 05-25-2015, 12:06 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
I just started doing local AutoX events. We run based on NASA rules and the SVX is in the NX-E class.
The first event had a very tight, and technical layout and I was not able to exceed 35mph. With Nevin's larger RSB the rear of the car rotated nicely. I noticed the steering is not very direct and takes quite a bit of input to go were you want to. (Better tires might help, leading to my point) My first run was a 75.847 and I got progressively faster. The last (6th run) was a 66.648 Out of 10 in the class I placed 4th and the fastest car in my class (Miata) ran a 61.092.
The second event consisted of a more open layout and I was able to hit 45mph. In this event I had to focus more on keeping as much momentum as possible throughout the turns. SVX is not exactly quick! Also, when I did use the brakes I had to use them hard and I wasn't always happy with the outcome. With the higher speed around corners I could really feel my sidewall rolling as well. My times were very consistent up to the point where it started downpouring. My first run was a 50.986, progressively faster again,with my fastest (4th run) being a 50.334.
So, I'm now looking for better tires. Something sickier with a stronger sidewall, but also not braking the bank (Under $150/tire) and lasting more than a season of AutoX.
I'm currently running the BBS STI wheels 17x8 ET 55 wrapped with Gmax AS03 (It's an Ultra High Performance All Season tire). They are surprisingly really good tires for the money (I paid $95 per tire) but just not up to par for the sport.
Any input on good tires? I'm all ears!
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
