Old 12-06-2006, 12:11 AM
Shop is Open
Instead of reviving an old thread an updating the Heck out of it I will merely post a new one.
My Shop is now open for business. I am not containing this merely to working on cars but also produing parts.
5/6mt kits will be available... (may want to check the thread in my signature for more deatails)-$800
Rear Bearing Full Assemblies(Full hub minus the parking brake with new bearings pressed in and seals)- $500
Group N motor mounts (Mounts along with modified SVX brackets) $200
Headers... 1 3/4"tubing for each cylinder about 30" long- $1500
ok now for the actual labor on the car
5mt conversion- $2000
6mt conversion- $2000
auto replacement- $500
Auto upgrade(4.11/4.44)- $800
Engine replacement- $500
Stage 3 install- $300
Timing belt/waterpump/frontseal replacement $250
Anything else will usually be charged hourly, $75 per hour and I will garentee my work but not used parts. Any questions please feel free to PM me.
Your loyal SVX mechanic
Old 12-06-2006, 03:40 AM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
Hi Tom,
What is a stage 3 install?
What are group N motor mounts?
Is your garage heated?
Sorry for asking dumb questions.
Dan
Old 12-06-2006, 04:51 AM
RSVX RSVX is offline
Network Design Administrator
Im guessing by stage 3, he means stage 3 from ECUTune...
Life is a game. Play to win.
Old 12-06-2006, 07:29 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Tom,
Give me a call so we can talk about who you might want to get headers and cams from
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-06-2006, 08:22 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Hooray the shop is open! . Time for Baileys!
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-06-2006, 08:51 AM
Originally Posted by DanSVX94
Hi Tom,
What is a stage 3 install?- ECUtune stage 3 supercharger
What are group N motor mounts?- WRX motor mounts... they are harder and can handle more abuse, they also allow for more vibrations to travel through the chasis
Is your garage heated?- It will be... not to mention I could throw a wrench and hit the Phil. Art Museum and the Ben Franklin Museum... Center City... Well, philadelphia for that matter
Sorry for asking dumb questions.-These are not dumb questions, believe me, I have had a lot worse
Dan
Dan, I replied in the quote to anser each question
Old 12-06-2006, 08:52 AM
Originally Posted by SVXRide
Tom,
-Bill
Headers will be built by your's truly if I decide to produce them. I am gonna make a set for my silver. Cams are still under review as of right now
Old 12-06-2006, 09:28 AM
SVXRide's Avatar
Tom,
Might be some options on the header front in terms of "bolt in" versus "optimized". Sean and I are working on some "optimized", SS, mandrel-bent, TIG welded versions using Harvey-supplied, computer model-based specs....which just happen to match up with the cams I'm working on
-Bill
Old 12-06-2006, 09:56 AM
I am not building a bolt in header... They will be built for my car and then an exhuast system to match. Hopefully I will acheive a 36" equal length for the car. I am still unsure of the tubing diameter I want to use.
Old 12-06-2006, 11:39 PM
snoryda28 snoryda28 is offline
soo...2800 and u got a 6 speed?
Old 12-07-2006, 03:35 AM
No... $2800 in LABOR... not parts.
$2800 is if you have all the parts on hand.
EDIT: He actually says $2000 for labor, not sure where you got the $800 from. I doubt you would find a 6 Speed for $800.
Old 12-07-2006, 04:43 AM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
I had to look twice to , the $800 is for the conversion kit assume, heck if i could have a 6speed for 2800USD installed id float my car over there and get it done haha
Congrats tom wish there was a shop in Australia
Cheers,
Jake
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 12-07-2006, 04:48 AM
5/6mt kits will be available for $800
This kit will be made to order and will allow you to install a 5/6mt without all the hussle and bussle of fabricating your own parts.
The kit includes the following:
....Custom X-member
....Extended shift linkage
....Modified Impreza pedal box
....Modified SVX brake booster
The price of the kit is $800, after $100 core for the stock parts.
In addition, you will need a 5 or 6mt transmission, and a driveshaft or have yours extended. Also, a custom shifter mount will need to be made in order for the rear portion of the shifter to mount to the car. I can provide this, just let me know.
Labor charge:
....5mt conversion- $1800
....6mt conversion- $2000
Anything else will usually be charged hourly, $75.00/hour. I will guarantee my work but not used parts. Any questions please feel free to PM me.
So that's $2600 for both the kit with custom parts (X-member, pedals, etc) and the labor to install a 5mt transmission for you.
Additional Items needed
....5mt WRX transmission (which I figure is about $1500 shipped)
....New or extended driveshaft
....Custom shifter mount.
I figure the total conversion, all parts and labor, is a little over $4600. I'm sure Tom will correct me if I am wrong. Now add a great shift knob, a custom leather shift boot and such and you could be revving through those gears for a little under 5000.
Old 12-07-2006, 09:05 AM
Ok I can see why you are getting confused so I will clear it up...
$800 is for the conversion kit and you want to do the install yourself.
That $800 is already included in the 5/6mt swap if you are having me do it, so the total for labor is only $2000 for a 6mt or $1800 for a 5mt...
I hope this helps
Old 12-07-2006, 11:43 AM
oh by the way. I have opened a new Ebay account for myself now, if you see me bidding and or selling the name is SVXSpeedShop
