No CEL or spark
Hey guys and gals. working on a customer's car and after the 5mt swap amongst other things, the car will not start now. I get no CEL when I turn the key to the on position and it will crank all day but no spark... I have checked mostly everything I can think of but it us just odd. If you can think of anything please make suggestions
Tom |
Tom,
On checking the wiring diagram with the transmission change in mind. ----There is a black ground wire which runs from a ground point in the original transmission, to the inhibitor switch which normally grounds two circuits from the ECU. Could you have overlooked this connection? My only suggestion at this stage, Trevor. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
Has the car got a bugular alarm some times they cause problems?
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
I have never had this issue before, mind leading me in the directions of this?
![]() Tom |
If you didn't miss that ground that Trevor mentioned, i'd definately see if there's a security system installed. Burgalar Alarm, I haven't heard that in awhile
![]() If there is an alarm, some of those have an ignition interrupt. Random thoughts from a random mind.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
Most burgalar alarms have one of two modes of operation, cut the power to the starter so you can't get the starter to turn over and the second is to cut the power to the igination. The first thing to check Tom is if the alarm has a switch on the key ring. If the car has central locking doors and it didn't come standard then I bet its the problem. My 1992 had that type of system and it also us to flatten the car battery.
That sounds to me like the ECU isn't getting power, check your fuses with a test light.
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta |
I am checking all the power inputs to the ECU and the available grounds. Anyone that can use a test light, check to see if plug B60 pin 12 is a ground or a 12v+ right now I am not sure and I need to keep checking the wire schematics and pin voltage charts
Tom |
i am printing out the other page of the pin-outs and I am thinking maybe the ignition switch isn't sending power to the ECU... Gotta head over to the shop to check... if anyone comes up with something I may be missing please call me at (609) 276 7279
Tom |
I've been on and off the phone with Tom for the past few hours. He found part of the problem, the "Check Engine" bulb has been removed by someone
![]() He has a bulb in, and now it lights when he starts it like it should, but it doesn't come on after and when he checks codes, it just gives the constant blinking "no codes". So, now at least he is past the ECU part of the equation, he has also spoken with the tech that installed the alarm and has ruled that out. It's still cranking, not starting because there is no spark, and not showing any codes... What else??? He forgot to take his laptop, his numbers up there^^^^
It's a single black wire - one end connects to a bolt on the firewall directly below the dogbone. Halfway up the wire is a plastic connector that just butt connects it together. The other half of the wire bolts to the tranny at the dogbone. I know it sounds odd for one ground wire to be the culprit, but it stopped mine from firing up when I changed my tranny out.
Ok, after getting rid of the jerry-rigged alarm system, I finally have spark again. I also have fuel.... but still no start
![]() ![]() ![]() Tom |
the alarm wiring sounds consistent for the car you're working on
![]() ![]() -Bill
thanks everyone
i just want to personally thank everyone helping tom on my car. tom has been the most helpful mechanic i've ever met to begin with.
