Old 11-19-2007, 12:26 AM
cruise on/off question
I hate that I have to turn the cruise on every time I drive the car. Why isn't it always on? I know that this is how it was meant to function. I want to know if anyone has, or knows of a way, to make the cruise always active. I don't want to hit a button w/ the left and then another w/ the right to get the cruise to engage. I find this very annoying. Anyone got any info about this? Any mods, special tricks, version of a rain dance...
blk 92' LSL w/ average mods
Old 11-19-2007, 01:06 AM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
I guess you could change out the switch from a momentary to a toggle switch, to keep it on at all times. Unless you want to turn it off, then just flip the switch to "off".
-Nate
'92 LS-L Pearlie
Old 11-19-2007, 06:34 AM
Manarius's Avatar
Manarius Manarius is offline
I would surmise that the cruise is not like that for safety reasons. With the way our cruise is setup on the steering wheel, it's farily easy to be set on, and you wouldn't want that if you were driving down town. I personally don't mind as that's the way it was on my old car.
-Jason
-Obi Wan Kenobi
Old 11-19-2007, 07:33 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
I wonder if it's possible to transplant the switch from, say, a recent Forester? My wife's cruise control lever has the on/off switch on the right side of the lever.
Old 11-20-2007, 08:25 PM
I like the idea of using a on/off swithc instead of the momentary one. I will try that fairly soon. Thanks for the ideas.
Old 11-21-2007, 12:17 AM
Most of the switches work that way. If the car is turned off, it stays off until you turn it on again. The other switch of off, on, and resume are the same as others too.
Old 11-21-2007, 12:23 AM
Hondasucks's Avatar
Subaru Technician
My truck is like that, it has an on/off switch on one side of the steering wheel, and a resume/accel and set/coast on the other side, so the cruise is always "on" but it won't "Set" unless you hit the set button, and if you shut the truck off it forgets the speed it was set at.. (Only annoying thing is most Chrysler products the cruise doesn't work below 35, rather than 25 like other cars)..
1986 VW Jetta
Old 11-21-2007, 08:33 AM
Guyver280z's Avatar
Guyver280z Guyver280z is offline
Send a message via MSN to Guyver280z
My cruise control doesnt work.... probably because of the 5 speed tranny swap.....
Old 11-21-2007, 01:13 PM
The cruise control system is capable of opening the throttles at any time, quite regardless of the intentions of the driver, thus placing those within the vehicle as well as anyone in front, in grave danger.
A momentary switch energises circuitry which is self locking and can be self unlocking. The system is arranged so as to be fail safe in the event of any fault and this could very well be dependant on the circuitry being able to self unlock. An on/off switch would defeat such an arrangement.
I may not be correct in my analysis, but if is very likely correct. I feel obliged to point out the risks involved in messing with existing arrangements.
Old 11-22-2007, 07:52 AM
SVXAPEAL SVXAPEAL is offline
Mine still works after the 5 speed tranny swap.
Caryn
1992 Dark Teal LSL
late 04 wrx 5spd man trans * kit by TomsSvx* ,exedy clutch,Stage 1v4 ECU chip. custom exhaust from the 02 sensors,K&N panel filter,phoenix gold 400w amp hooked up to the stock size speakers with JVC head unit w/remote plays MP3's, Refinished headlights with acrylic coating,7500k blue bulbs low and high beams and yellow fogs,yokohama avid v4s
Old 11-22-2007, 11:38 AM
jeffast jeffast is offline
I kill more trannies then god
mine also works fine with the 5 spd swap
1991 xt6 eg33?
1993 gc track car
Old 11-22-2007, 12:36 PM
Mine too. It sometimes give a little surge, but is usually just fine.
Old 11-22-2007, 12:57 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
have you checked the vacuum connection on the servo yet?
- John
