timing belt service
a mechanic friend of mine is going to replace the timing belt, crank, and cam seals. Is there anything I should definitely replace while everything is apart?
Thanks, Matt. |
Water pump if the mileage on the current one is above 100k
Pumps tend to go at 150k give or take and it's not fun if it seizes. Should be around $50-70 for a genuine subaru pump plus 15-30 minutes to do it. |
If you decide to replace the water pump you will also need the water pump gasket, thermostat and the gasket for that.
P.S - I am running a special on the SVX Timing Belts so take a look in the "For Sale Section" |
