Sounds Like Bearing!
I recently put in some front bearings I bought when I did my rear bearings a few months ago. When starting, I noticed a torn outer boot on the driver side axle (grease everywhere!). Soooo, I replaced both front axles (reman, Napa, $60), installed bearings (I had been hearing whining bearing type noise for some time), rebuilt calipers (seals, booties) and installed high-tech pads (EBC Green Stuff Kevlar front, Akebono ceramic rear).
The whining bearing type noise is still present! Tell me I don't have a bad rear or front bearing so soon! I took all care not to damage hubs or bearings during removal/installation (used HubTamer). Is there another part that might be causing such a sound? LIKE A DRIVESHAFT U-JOINT, OR A DIFFERENTIAL NOISE? Also, I've balanced my front tires twice (NASCAR machine) and still get intermittent steering wheel shimmy? RACK AND PINION? MOTOR MOUNTS? HEEEEEEEELLLLLLLLLLP! THANKS!
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! |
It could be tire noise. Switch the front and rear?
