Electrical question...
Hey guys... I have a question(s), I hope someone can help me with. I have an electrical problem, that has started recently and its drivin me nuts. I cant say for SURE that it started when I replaced the battery, but it never did it before. And the problem I am discussing, may be two problems.
Sometimes it wont start, the key turns and... nothing... all the idiot lights come on, etc., and nothing. Then, if I turn the key real slow, and sorta find this spot, before the key is all the way turned, it sorta "catches" and starts up. Also, sometimes it will just cut out, and the tach will bounce around, the lights will all dim, and the motor will run rough. I will rev it hard, (like 6K or so) and it will "click" back on, and be ok. It seems to do this, after it has been driven and then sits a while. I honestly cant even tell for sure if the issues are related. Ok... its weirdin me out... can anyone help? Any of this sound familiar? I would appreciate any insight anyone can provide. I have been workin on this car alot lately (all good\fun) work and I've really have been puttin the miles on it. This car has really grown on me, and I want to get this sorted out. Thanks... Sonny |
Are you sure your connections to the battery are clean and tight? I know it sounds obvious and stupid, but you would be surprised at how many times it's the simplest thing. Especially since it just started after battery replacement.
Yeah, that was the first thing I checked. I have made sure they are good to go.
This sounds similar to the problem I had with a worn out key. I could turn the ignition PAST the start and it wouldn't catch until I backed off the key a little. Plus while driving, the key would fall out sometimes.
I switched to a spare key I had and everything has been groovy since. Doug
First, check the small body ground (the "thin" black wire going from the neg terminal to the body, just in front of (between the headlight and battery). If the body side of the little "eyelet" connector is rusty, or loose, clean it and tighten it. Check to make sure you didn't, perhaps, break a post (try wiggling the cable and see if the post flexes). Double check the connections to your alternator. Make sure they're tight and clean. Check the condition of your fusible link (in the fuse panel under the hood). I had electrical problems with my car when I first bought it and found that some eediot had replaced the fusible link with a piece of copper wire -- damn near set the fuse box on fire.
Well, it very well may be a ground issue. The people that had the car before me had installed some sort of stereo equipment, and replaced, both the pos and neg cables. Do you think just building a ground from the neg. cable to the body might be the ticket? Thanks...Sonny
Hmmm. Is your original ground missing? If you're going to go to the trouble to do that, you may as well do the alternator wiring upgrade. Check the "How-To" personal locker for complete details. If you have any specific questions about the upgrade, there are many of us who have done it (I did mine and 1994subaruSVX's) and can help walk you through.
Well, from the pic's it dont look too tough. Whats the story? What is this mod about, and what is it accomplishing, etc., Thanks for the assist. sonny
http://www.subaru-svx.net/forum/show...wiring+upgrade
Thanks, Aredubjay... Soon as I get a chance, I will round up the parts and give this a shot. Dont look too tough, and might do me some good. Since my ground cable has been butchered and replaced with some aftermarket substitute. Do you think I should also build a ground from the neg., terminal to the body? Thanks again for the help\info. sonny
Definitely. I used two different sized lugs on my wires, but, yes, attach one end to the screw on the cable and the other end to the screw that sits in front of the battery (between battery and headlamp). There should be a small ground wire there already and you can just "piggyback" the two "eyelets." If there isn't one there, that may be your problem. Best of luck.
