sunroof weather stripping replacement
does anybody know how to change the sunroof weatherstripping?
i mean, is it straight forward or is there a trick to it? thanks
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
The sunroof weather stripping does not keep water out... If your sunroof is leaking, then the drains must be plugged up, there is a drain in each corner of the sunroof, check to make sure they are clear...
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
It's easy to change. I took mine off to see if that's why the sunroof wouldn't open on its own...it wasn't.
To remove just slide it down to "unclip" it.
