Old 03-22-2004, 03:32 PM
Tiamat-red's Avatar
Tiamat-red Tiamat-red is offline
Following the path of the beam
Question How do I check the timing?
I know we have direct fire ignitions and I couldn't change the timing but how do I check it? On my civic I'd just hook my inductive timing light up to the #1 plug wire.
But how do I do that on my SVX? And since I'm on the topic, how are the cylinders numbered anyway?
Thanks!
Matt!
92 Ebony LS-L "Jabberwerwok" Now includes 1 *free "Wheeeeeee" per ride!
83 Honda Magna v45 "Grendel"
*Free after mail in rebate
Old 03-22-2004, 04:29 PM
timing
The timing can be checked with a subaru select monitor, the initial timing is 20 degrees BTDC, and runs up to 50 degrees BTDC.( As memory serves,) the passinger side front is # 1, the pass side middle is #3, the pass side rear is #3, the drivers front plug is #2, middle is #4, and the back drivers side plug is #6.
Old 03-23-2004, 10:35 AM
svx_commuter's Avatar
#1 is RH front and #6 is LH rear.
A conventional timing light will not work easily.
The best way would be to install a spark plug extension wire between the coil and the plug. Then it would work.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
