Dark oil? I just changed it...
After breaking my crankcase breather and dropping its shards into the crankcase; my dad and I decided that it would be good to flush the oil. The oil that was in the engine was really dark, and I had just changed it 500 miles ago! What is that all about?
Re: Dark oil? I just changed it...
One other possibility that I HOPE is not the case: you didn't drain the front diff and then fill the crank case again, did you? "Jiffy Lubes" have been known to pull this bonehead stunt.
Couldn't warm it up first because of the crankcase breather mishap; that was why we were draining it in the first place
Hows the car running? how is the fuel economy? Rich mixture can contaminate the oil early. Any black smoke from the tailpipe? Check your airfilter.
Mike |
By the way, I wanted to add that my suggestion is far more unlikely than what the prez suggested.
Oh, well, okay. So if it's not warmed up and/or tilted it's darker? Also I replaced the air filter upon seeing it after taking off the intake hose stuff to clean the throttle...it had pine needles and sludgey looking stuff on the underside...
Good call on the air filter. EEK! Sounds nasty. ![]()
![]() ![]() ![]() Also, does a person necessarily HAVE to use a crow's foot to get the PVC valve back into the engine? I got it tight enough with a regular wrench but I didn't know if that means it's threaded wrong or not tight enough,... |
I would recomend NOT tightening the PCV real tight. Someday you will have to get it back out. It is a pipe thread and will seal with only a little force. Won't loosen either.
Mike |
I didn't use a crow's foot. I wound up using an open ended wrench. It's just a pain in the butt and a very short "throw," to say the least. I hope you were using a shop vac, and not "mom's pride and joy Electrolux" or something. If you used the latter, I'd get the SVX up to speed in no time and get the heck outta Dodge. When ladies start swinging brooms at you, it can really be painful!! ![]()
AMSE?
Garrett
Did you visit the American Museum of Science and Energy in Oak Ridge this past weekend? We were coming out of the shopping center and saw a black over claret pulling out of the parking lot. Was that you?
bill Green 95 SVX - Cleo Green 97 Outback - Maxine Red F-150 Extended Cab Long Bed - Big Boy Even the best monkey sometimes drops his banana. |
Re: AMSE?
