Old 05-18-2024, 07:43 PM
Power Steering Pump Bearing?
Looking through the how to documents as my power steering pump is showing symptoms of a noisy bearing.
Part 31263GA840 is discontinued, and I am trying to find information on a suitable aftermarket replacement.
Thanks in advance.
Old 05-22-2024, 03:00 AM
Re: Power Steering Pump Bearing?
Took my core PS pump apart tonight.
OD 35mm, ID 15mm, 11mm width are the specs. Ordered some timken bearings that match the spec of the NTN that was in place.
https://www.amazon.com/TIMKEN-15x35x...l%2C157&sr=1-1
Old 05-22-2024, 04:20 AM
Noriyasu Noriyasu is offline
According to my notes when I took it apart, the original bearings were 6202LH made by NSK. You should be able to use compatible products such as NSK's 6202VV or NTN's 6202LLB.
As you know, size are d=15, D=35, B=11
If available, I recommend to you also replace the front and rear oil seals.
Old 05-22-2024, 08:34 AM
According to my memo, it seems to have been overhauled in October 2020.
34481 31263GA840 Ball bearing, power steering pump => use 6202LLB instaed
34488F 34424AA000 Oil Seal Pump
34488A 31263GA890 Seal O-ring
34488B 31263GA900 Seal O-ring
34486 34437PA000 Lock pin pump discontinued
34482 34425AA000 Gasket pump discontinued
34418 34432AA000 Spring Canceled
34488B 34427AA000 Seal O-ring discontinued => use Third-party product Inner diameter 13 Thickness 2.5mm
34488C 34427AA010 Seal O-ring
34415AA051 Connector/Pump Assembly Discontinued
FYI
