Old 03-02-2010, 11:01 PM
Thumbs up Classic Registration Certificate
I am sure some of you have heard of the Classic Registration Certificate that the SVXWN does. It will help us get Classic Status someday. If you want to look at the history of this, check this thread out.
I will put a list of the members who have purchased one of these certificates and if others want to register, they can do so. If you want to see what they look like, click on the doc at the bottom of the page. We can do the same for members in other countries as well.
We will have a nice badge for members who have done this. You will see it when we have it done next week. If you have any questions about this, let me know.
Old 03-02-2010, 11:18 PM
Re: Classic Registration Certificate
The list of members who have had their cars registered as Classic Status through the SVXWN are as follows:
1) ensteele
2) Shotgunslade
3) svxcess
4) Wannarace928
5) TomsSVX
6) bwb3
7) CorSVXette
8) HOP
9) Mission
This only needs to be done once for the owner. If ownership changes, a new certificate would need to be done for them. As time goes on, this should help to show that this organization has members with this classification.
Old 03-28-2010, 01:55 PM
We now have the badge. It needs to be tweeked a little, but it will look like that, but just moved up a bit.
We now have subi-crosser who has joined the Classic Registration group.
1) ensteele
2) Shotgunslade
3) svxcess
4) Wannarace928
5) TomsSVX
6) bwb3
7) CorSVXette
8) HOP
9) Mission
10) subi-crosser
Thanks for your support and I hope that we can get this classification for the SVX soon.
Old 03-28-2010, 02:34 PM
Green1995SVX's Avatar
Earl-
Am I missing the instructions on how to apply for this certificate?
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-28-2010, 04:19 PM
Post #1 has this: check this thread out. Follow that link and you will get the information on it. If you still have questions, let me know.
Old 03-28-2010, 06:46 PM
The day has come that we can finally do these Registrations. They are 8 1/2 X 11 and on cardstock. They are done in color and look nice enough to be framed.
1) The Donation of $30 by check or money order will get one mailed to you.
2) If you use PayPal, the amount will be $35.
3) If you want to register a second or more cars, the donation will be $25 each after the first one ordered at the same time. This will save postage and packaging.
4) These certificates are numbered.
PayPal address is: svxwn.paypal@svxwn.com
The information needed to do this for you is as follows:
Name:
Handle or Forum Name:
mailing address:
City, State, Zip:
Year of SVX:
Trim (L, LS, LS-L etc.):
Full VIN:
Date of Manufacture:
Color:
Miles:
Date you joined the SVXWN:
This informaiton can be emailed to me at: ensteele at gmail dot com.
If there are any questions, please don't hesitate to contact me.
Just because the link to that was sort of buried in that thread.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 03-28-2010, 09:50 PM
1) ensteele
2) Shotgunslade
3) svxcess
4) Wannarace928
5) TomsSVX
6) bwb3
7) CorSVXette
8) HOP
9) Mission
10) subi-crosser
11) Green1995SVX
Old 03-29-2010, 04:24 AM
shotgunslade's Avatar
Earl:
Sent you a PM. Can't find my classic registration certificate. Need a pdf or doc copy if you can send. Thanks.
Old 04-11-2011, 10:36 PM
Send me your email address and I will send you a PDF.
Old 08-12-2012, 06:11 AM
gjhumphris's Avatar
gjhumphris gjhumphris is offline
[QUOTE=Originally Posted by ensteele
PayPal address is: [email]svxwn.paypal@svxwn.com[/email]
Name:
mailing address:
City, State, Zip:
Year of SVX:
Full VIN:
Color:
Miles:
If there are any questions, please don't hesitate to contact me. QUOTE]
Are Australian delivered SVXs able to be classed as "classic" too? If so, are the above details still correct to obtain a "Classic Registration Certificate"?
Thanks,
Grant
Old 08-12-2012, 11:30 AM
The certificate is a great value. Used it to get collector car status in NJ. Can drive (3000 mi per year) even even though my Tomstock Version 2 engine failed emissions. Also got insurance (100-300 liability, collision, comprehensive and UIM for $15,000 negotiated value, $500 deductible) from American Collector Car Insurance for $280 per year. Good value for the certificate.
Old 08-13-2012, 07:58 PM
Name:
mailing address:
City, State, Zip:
Year of SVX:
Full VIN:
Color:
Miles:
Thanks,
Grant
If you send me your information, I will fill one out for you and you can see what it looks like.
Old 08-10-2014, 07:11 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Can anny one get the classic registration?
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 08-10-2014, 01:46 PM
Yes As long as I can get your information.
Old 08-11-2014, 09:32 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Still waiting for mine.
Gene
Gene and Ben
