Old 03-21-2009, 09:55 AM
powerdog powerdog is offline
adjusting brake band - dealer told me
A few months ago I asked about a slipping trans. a user here suggested maybe adjusting the brake band. Put the car on ramps today and realized it is more than I can handle (after reading a script on how to do it). I just called a dealer and service tech told me that they don't adjust the brake band to correct a slipping SVX transmission. They do that after the trans is rebuilt. Can anybody tell me the real deal? If my transmission is slipping (I believe between 3 and 4) is it possible that a brake band adjustment can cure the slippping? How is it determined that a trans needs rebuilt? Thanks as always.
1994 SVX L FWD
"The Blue Bullet"
Old 03-21-2009, 09:59 AM
Re: adjusting brake band - dealer told me
Usually when the transmission has a flair between 3rd and 4th, or 2nd and 3rd, it means that your transmission is on its way out. Some have adjusted the bands, but only when it just starts. I am sure someone else will speak up here and correct my statement if I am wrong and give you more details. Good luck.
Old 03-21-2009, 10:07 AM
longassname's Avatar
Just some dude.
ya that's a brake band. it's probably shot and not just needing adjustment but adjusting it may keep you on the road a little longer. You should also check your tps sensor and make sure it's adjusted right so you aren't getting low line pressure.
Old 03-21-2009, 10:13 AM
Just some dude.
it should also be kept in mind that tighting a worn brake band even if it does keep you on the road will lead to damage to the reverse drum. It's also very likely the high clutch isn't far behind but as long as your acceleration in 3rd is good it doesn't sound like it's shot yet so like i was saying..it's possible in your case that a brake band adjustment will keep you on the road a while longer but at the same time yes your transmission is on the way out.
Old 03-21-2009, 11:13 AM
S**t oh well. It seems as though if I just drive it "normally" I can feel it slip a bit (not terrible but it is slipping) but if I more or less mash on it, seems like it almost doesn't slip at all. Just womdering if something is speed related. Either way it sound slike I'm a goner or the tranny is I should say. Thanks
1994 SVX L FWD
"The Blue Bullet"
Old 03-21-2009, 11:19 AM
Just some dude.
could possibly be your throttle position sensor is off so you'll want to look into that either way even with a new transmission that will need to be right.
Old 03-21-2009, 11:40 AM
talked to a guy up the street, gas station owner that does mech work too. He said take a gamble and flush the trans first and see if there's a difference...Also said forget a rebuild get a new trans. Any thoughts..on either point?
1994 SVX L FWD
"The Blue Bullet"
Old 03-21-2009, 02:36 PM
Just some dude.
a flush won't do anything. I don't believe new transmissions are available. Subaru offers remans which come with a one year warranty but have the same weaknesses as always (slow shifts, weak high clutch, band slips too much). I build transmissions that shift fast, have higher apply pressures to prevent high clutch and brake band slippage, have a stronger high clutch as well as a couple others, and better friction materials all around. You should ask svxfiles about it. He just installed one of them for one of my customers. I believe he's conveniently close to you. You could have him install one for you too. It will not only last you longer than anything else you can get--it's the single biggest improvement you can make towards making the car more fun to drive.
Old 03-21-2009, 02:49 PM
#1. DO NOT POWER FLUSH YOUR TRANSMISSION!
To drain and refill it is fine.
#2. You are not that far from me if you would like to get your band adjusted, TPS adjusted and trans checked out on a factory Subaru Select Monitor.
(At the least disconnect the dropping resistor located between the battery and the inner fender.)
#3. A professionally rebuilt transmission done by an expert is actually better than a new factory transmission.
#4. Currently the only Subaru transmission expert that is building transmissions for us SVX addicts is LAN anECUTune down in Florida.
I just installed one of his rebuilt transmissions a few weeks back, and the shifts were firm, quick and very positive!
Tom Krynock
301-707-3437
Old 03-21-2009, 04:30 PM
oab_au oab_au is online now
Tom Krynock
301-707-3437
Does Mike do FWD boxs?
Old 03-21-2009, 04:35 PM
Yes.
It's on his website.
Old 03-21-2009, 05:34 PM
Just some dude.
did one for vicsvx just a few weeks ago.
Old 03-23-2009, 10:18 PM
oregondave oregondave is offline
Tom Krynock
301-707-3437
what is wrong with flushing it? I had the fluid flushed on my first svx and it fixed the rear axle binding.
Old 03-23-2009, 10:36 PM
When I worked at the local Subaru dealership the "power flush" was pushed heavily.
At the time it was about $100.00 for the flush.
Mechanics would hook the car up to the machine, add the 110psi airline, blow the accumulated sludge out of the transmission, and two weeks later fuly 1/2 of the people had transmission failure!
The simple dealers answer was that your trans was ALREADY going out.
Sorry Pal.
Drain and fill.
Unless the only use the system that uses the front pump of the SVX transmission.
Old 03-24-2009, 08:57 AM
Sorry Pal.
Drain and fill.
I hear you but you still didn't explain why the flush is a bad thing.
