Replacing steering wheel, cruise question
Hi guys... I recently acquired a late model Momo steering wheel, with cruise control stick, from a late model legacy. I know some of you have fitted these to your SVX's. Is there anything I need to be aware of? Will the cruise control stick simply "plug & play"?
Also, my SVX is non-SRS but the wheel I got has the airbag. any issue simply leaving it on but disconnected? Appreciate your help |
Re: Replacing steering wheel, cruise question
I fitted a wheel from a WRX STI Version 8, the connector for the cruise lever was different, but the wiring had the same colours, I cut and solderd, air bag wiring was also different, never used the air bag on my UK 96 and the 92 JDM doesnt have air bags.
On the 90s MOMO LGT wheel I put in mine, there was a spot to mount the cruise control stalk from the SVX wheel, so I used that. If the plug is the same, just plug it in an it will most likely work just fine. Otherwise, you can probably mod it to use the SVX stalk, as long as there is room to fit it in there.
There should be no issues with leaving the airbag disconnected, but you might want to cover the connector with electrical tape for safekeeping.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
