Clock brightness problem
The clock lighting randomly changes from the full bright daylight mode to dim night mode. Doesn't make any difference if lights are on or off. The rest of the dash light work fine. It is just he clock. Any ideas on what to check?
Re: Clock brightness problem
I noticed this recently too. I yanked out the cig lighter and it seems better now. However, the clock didn't immediately get brighter so that was very odd. I was going to replace the lighter and see what happens.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
