Old 05-28-2024, 02:30 AM
Resistor in engine bay
Is it normal for the resistor for the transmission (the JECS one) located on the left apron next to the battery to be warm to the touch? This feels incorrect and I may attempt to source a replacement.
Old 05-28-2024, 02:37 AM
Re: Resistor in engine bay
will likely follow this guide and swap this soon https://www.subaru-svx.net/forum/showthread.php?t=29344
Old 05-28-2024, 08:00 AM
Noriyasu Noriyasu is offline
Is it while idling? Or, after driving a while?
If you are not in such a hurry, I will check it out as I have something to do at SVX on the 11th.
Old 05-28-2024, 03:43 PM
SVX_MY_BABY's Avatar
See post number 10 in your link above:
Originally Posted by oab_au View Post
Yes that was easier and cheaper than replacing it with the Subaru part.
I do have some concerns about the way the wires run. As you know that resistor can get very hot, and the way the plastic covered wires are between the resistor and the body, could melt the insulation to cause a short.
It may be better to run the wires around the outside of the resistor. It won't look as neat as the way you have done it but it woun't melt the insulation either. Just a suggestion.
Peter
Old 05-28-2024, 09:55 PM
Smile Re: Resistor in engine bay
I would not worry abut it Mike, it's supposed to get hot, its dissipating power by dropping the 12V to 5V.
Old 06-02-2024, 04:49 AM
Thank you both. I pulled the resistor, inspected it and it looks good so I’m leaving it. If it had physical damage I’d be more inclined to replace it.
Old 06-11-2024, 08:01 PM
I drove SVX about 600km yesterday. When I got home, the resistor temperature was about 70C (160F).
FYI
Old 06-13-2024, 08:06 PM
FYI
Thanks Noriyasu! That’s about where mine is as well.
