Mirror Adjustment Lamp
Has anyone attacked replacing the lamp behind the arrows on the mirror adjustment switch? I've pulled the switch and there is no "visible" access to that lamp. Do you have to pry the "arrow" portion of the switch off to access the lamp? Thanks in advance.
Hey, sounds like a job for KuoH! I think that guy has tackled every light in the passenger compartment.
-joe- |
<<Has anyone attacked replacing the lamp behind the arrows on the mirror adjustment switch?>>
There is a light in there? I've never seen mine iluminate since I've owned it. Thanks for making me go take it apart looking for one to replace... Doug
<<Good. Once you've done it, let me know what you find.>>
OK. I'll do that. Doug
Mirror adjustment lamp
I will check mine tonight. I swear that my switch illuminates only the four little directional arrows on the round control. However, the parts book from subaruparts shows only the switch with no replaceable bulbs. The breakdown of the other switches shows the replaceable bulbs/LEDs for them.
The part number for this switch is 83071PA020MD and runs $50.36 from subaruparts.com
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-11-2001 at 03:00 PM. |
Re: Mirror adjustment lamp
There had better NOT be any light bulbs in that little disc that I set once, and never touched again, and I couldn't see anyway, 'cause it's blocked by the turn signal arm anyway. I mean if they really bothered to light up THAT thing, and NOTHING under the hood, my faith in Japanese ingenuity will be permanently diminished.
Tsu.
Good s**t happened. ![]() '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
I disasembled it.
OK. I took out and apart the mirror switch. There is a replaceable bulb inside, but in a different socket than other indicator lights.
Here's the way I did it. I took three small flat pocket screwdrivers (the kind they give away at various shows and such) and slid one under each grey (or beige) tab on one side of the assembly. Then I gently held the assembly in one hand and gripped the black connector with the other and rocked the connector away from the screwdrivers. That released one side without damage, then I took one screwdriver and released the three remaining tabs one at a time. When you remove the connector assembly (the black part) have the face (with buttons) down to avoid losing parts all over the place. Look at the inside of the black assembly and you will see the illuminator resting in a red rubber sleeve. Grab the bulb assembly by the green skin and slide the rubber socket out. remove the bulb by unwrapping the leads and then remove the green condom. I'm going to walk over to Radio Shack this morning after they open and see which bulb fits. Assembly is reverse of disassembly. Enjoy! Doug
Re: I disasembled it.
green condom.
I told you that they don't keep forever in a wallet!
![]() So there is a bulb *inside* my mirror aiming toggle? I wonder what other bulbs are toast in the cockpit. Because I do a lot of night driving on country roads I have the instrument lights down low almost all the time. Maybe that's why I don't notice thier absence so much. Not only that I sometimes enjoy groping around in the dark ![]() |
<<Not only that I sometimes enjoy groping around in the dark>>
Too much information. Didn't you once tell me that you drive alone most of the time? How'd you fare the storms last night? We had quite a windy time up north der hey. Doug
radio shaft
I went the Radio Shack route for the dash button lights and found an "almost" fit #7219 Micro Lamp. They are sold in pack of two for a buck or so. They are too short (at least for the lamp bases in the dash switch assemblies). They barely extend beyond the end of the base, and thus put out very little light. I took a piece of heavy guage speaker wire that fit securely into the base, stripped off the insulation, and cut this into little pieces to use as spacers between the lamps and the bases. Viola. Slide the little green "hat" back on and you are good to go. A very cheap easy fix.
That makes two, and only two, cheap easy fixes that I know of for the SVX (The power steering O-ring being the other). ![]()
First the smiles, then the lies. Last comes gunfire. |
The operative word there is *most*.
The storms last night were mostly lightning and noise with a whole bunch of rain. Surprisingly not too much wind out on Wind Point. Of course when the rain first started coming down the suddenly remembered the patio umbrella was still open. There's our hero, out in the pouring rain at midnight cranking the thing down so it won't blow away. And then at 2 am when the cats decided they wanted in. meowmeowmeowmeowmeowmeowmeowmeowmeowmeowmeowmeowme owmeowmeowmeow Hey, that's why I'm so tired today. ![]() |
<<Surprisingly not too much wind out on Wind Point. >>
Uh . . . um . . . not too much . . . uh . . . that's just too confusing. ![]()
