Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 06-21-2014, 08:08 AM
radarwhiz's Avatar
Fairmont State University
Subaru at the Ring!
WRX STi starts 3rd in class at the Nurburgring 24 Hours.
Live stream:
https://www.youtube.com/watch?v=pMIDFQxFKJw#t=7402
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 05-20-2015, 11:28 PM
JasonNorin's Avatar
JasonNorin JasonNorin is offline
Re: Subaru at the Ring!
The video is not available for public viewing, dude. It says "This video is private".
Writes sports news as a freelance writer.
Old 05-22-2015, 02:39 PM
wdb wdb is offline
dances with roads
A little tough to read but it looks like it may have finished first in class!
http://www.subaru-msm.com/2015/nbr/report/race/24
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 05-23-2015, 12:48 PM
shotgunslade's Avatar
Go to English language version of the site:
http://www.subaru-msm.com/global/news2015/15011.html
