Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 10-01-2014, 05:10 PM
Stock AXers? Your PAX is going up.
http://www.solomatters.com/street_ca...moves_for_2015
If the proposal for into effect. The SVX will be HS after 1/1/15. Thoughts?
Old 10-02-2014, 12:40 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: Stock AXers? Your PAX is going up.
Not sure the big list is a proposal. The same, with the Fiesta ST and Mazdaspeed 3 moves, Ruth's numbers should prove interesting.
With 2014 indices, this is a .540 second advantage on a 60 second course. In most regions, it'll be a slight shove northward in the list of also-rans.
Old 02-22-2015, 06:01 PM
solodon solodon is offline
I finally have my SVX and plan to solo it, among other things. I ran in SCCA Solo for over 20 years but have been away for over 10. Could someone help me with the preferred tires, sizes if different from stock, and starting air pressures? Thanks.
Don
Old 02-24-2015, 01:11 PM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
Hankook RS-3 Version 2s seem to have good reviews from the auto-x guys. I bought them for my 2.5RS, and will be getting them mounted as soon as it warms up and the salt washes away. I would stick with 225 width unless you want to put 245s on there maybe. I haven't run them yet, so I can't help you with pressures. I ran the old Version 1s, but my RS is 800lbs lighter than an SVX, so the tire pressures that work best would be different anyways
Old 02-24-2015, 10:12 PM
Thanks, those are the ones that some seem to like. Now to find some wheels so I can swap between events.
Don
