My only tip is thig: I have not yet successfully removed a Subaru axle nut. On my SVX, I tried for over an hour. On the Legacy, I gave up pretty quickly and tried another solution to the problem I had to solve.
The axle nuts are on very tightly. Jumping on a 24" breaker bar, I was unable to loosen the SVX's axle nut. On the Legacy, I used a piece of pipe to make the same breaker bar over four feet long, and I was still unable to crack it. If you get yours off, let me know how. Next time I'm packing explosives.
Weird. I helped to change two axles and we didn't have any problems with loosening the nuts, once we straightened out the notch. You did do that didn't you?
KuoH |
(chances are you'd get the rebuilt axles coming off MY car.)
You could always slip someone at the tire shop $5 to loosen and re-torque the nut(s) for you. They weren't torqued that high at the factory but with so many hot and cool cylces they do tend to be difficult to break free. Either that or you're trying to turn them the wrong way.
Is either one reverse threaded? And, yes, I unstaked the nuts on both axles - it didn't matter because I couldn't get them to budge anyway.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED 92 Teal - painted yellow/4.11 5spd/n2o SOLD 92 Claret - 4.44 SOLD 94 Barcelona - FWD SOLD 92 Ebony - 3.90 SOLD 94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims |
