Changing pads and rotors.
My rotors from Motorsport Wharehouse arrived at my house today. On Thursday we will be putting them on along with new pads. My only question is this. Is there anything I should know about changing these pads. I've done it on numerous cars, but when it comes to these things, the SVX always seems different. If you guys know anything that will help me do the job easier that'd be great.
Thanks
See my car @ http://www.nicez26.homestead.com/NicolesPage.html |
I would say the SVX is one of the eaisiest cars to change brake pads on, if you have expirienct with other cars this one should be a snap. Good luck.
ROTORS and PADS!
Wondering if you got the cross-drilled rotors ($200 each) for the front like I did. Mine came with two drill holes missing! I ended up drilling the two missing holes myself. They are working OK - I'm getting them turned now (1 1/2 years later, about 30 K miles). [It turned out for me that the new fronts made no difference>> IT WAS THE REARS that were warped!]
Pads are routine, nothing tricky. Have FUN! ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
Go to www.ryanmacdonald.com then click "Sunfire/SVX" on the left hand side, then scroll down to "SVX howto's". On the next page there will be a selection for a brake how to. Very descriptive and should help you out alot!
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs. http://stickyvinylgraphics.com/ |
I ordered the set of 4 Brembo I think slotted zinc coated rotors. They were less than $400 for the set. Really good deal. I'll check that out. Thanks alot.
