#31
I understand what you're saying with regard to overtaking power, but it hasn't been my experience with my own car that that is the case. Obviously it's hard to know without dyno plots but the car doesn't seem any slower. |
#32
what if
what if instead of a resonator u put a small muffler there?? would this do anything? then just run pipe from there out the rear? bear with me as i dont really know much about this stuff at all just an idea....
Jim ![]() |
#35
-Bill
#37
I had this done on my car last summer. New pipe from center cat back to a 4" dia. 14" muffler to stock muffler. Total cost with labor ...$60. No more rattle, buzz, or weezing. This was a independant shop specializing in custom systems. I anm very pleased with this set up. The resonator is NOT a cat. It is a sound suppression device. Good luck!
"oh blessed mother of acceleration don't fail me now!"-Dan Ackroyd: BLUES BROTHERS '92 Teal LS-L Sold to North Carolinaians! ![]() 1972+'73 BMW 2002 tii('72) someday I'll finish restoring them,...someday (for sale) ![]() |
#38
Resonator
I got Dayles resonator for under $50 and had it put in at a local shop for $25.
Sounds almost like the original exhaust. Maybe a little throatier. The shop said they could have sold me a glass pacl that would do the same. I have no Isea if this is true, but I like it as it is now. I would do it all over exactly the same today. Ryan |
#39
I don't think that the EURO system is similar to the US system, but I have "sliced" up my resonator and modified it a little.
![]() This surgey was called by a ratteling noise at 2200 rpm, and was diagnosed (by listening under the car) to be the resonator. I just opened the bottom of the whole thing, and welded the loose "middle" wall in place, wich was emitting the noises. I then made some more holes in that middle wall to improve flow, and welded the the bottom piece back. If I can remember the layout inside the resonator I'll maybe make a drawing of it's principials ![]() The operation resulted in a noticeably increase of power in the high rpm area, and no sound increase. After this, I "slipstreamed" or maybe "slipjointed" with a Porsche 911 to a amazing 267km/h ! , but then again, I DO HAVE A EURO version, and added to that, A -92 , wich are claimed to be the fastest ![]() ![]() ![]() /Sonny ![]()
Internal name: "SuperSonic" ![]() -92 ebony black with 170k KM ![]() *** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. *** |
#40
That sure is a lot of work! You can get an aftermarket for 30-50 bucks! Then again you saved some money!
#41
hmmmm
no one said anything about my idea for the small muffler in its place that mean no one tryed it or its just too stupid to work??
Jim ![]() |
#42
Sure, but I cannot imagine that there is a "bolt on" replacement that matches lenght flanges and so on, so if you buy a replacement, you have to cut and weld anyways
![]() /Sonny ![]()
#43
And sure, why not a muffler, but the resonator is not a regulary muffler, it is sort of more tuned in it's function.
But then again, why a muffler? , weld in a pipe instead! I have built MANY exhaust systems of aftermarket , standard parts, and they work just fine. On my turbo engines, I have just two mufflers of the "straight thru" model, and they are very nice. This is possible because the turbo itself is a very good muffler! On my XT, I had a 3½" downpipe , then a 3" small muffler, then a 3 to 2½" adapter and last a little bigger muffler (nice tones ![]() But if you add a muffler in the SVX's resonators place, make it a 2 - 2½" straight-thru type. /Sonny ![]()
#44
i don't have a straight pipe through my resonator i have a rattly one
however i have heard svx's with a straight pipe through there and it sounds raspy to me i think a couple people have had success at replacing it with a cherry bomb glass pack and not have any noticable change on my impreza, i have a full cat back custom exhaust system with no resonator, it's 2.25" pipe the entire way back, and the car is much faster than with the stock 1.75" pipe and resonator through the entire powerband, it also has an aftermarket muffler on it as well... and the car is loud, very loud, it sets of car alarms... what does this have to do with the svx resonator you ask? my suggestion would be if your going to have it into the exhaust shop have them replace the entire pipe from the cat to the muffler while they're under there, shouldn't cost much more, mine came to 60 dollars total and that was including mounting and hanging and welding in the SS muffler. i went to a minekee however where i was recomended because of one of the guys working there i have been back since and found that pennsylvania has passed laws disallowing the change of exhaust by a shop from what was on there at all, if it has a muffler here and here it needs one when they're through if it has a cat here and here it needs one here and here when they're done.
SV What? |
#45
I brought my svx to the local muffler shop and I told the guy that my car was making an annoying rattling noice during certain rpm's. I then told him to just replace the resonator with a straight pipe. He put it up on the rack, banged a few spots to see where the rattling was coming from. Then he found that the heatshield was loose. He wielded a few spots, and 5 mins and 10 bucks later, no more rattling heatshield.
