I'm using about 1 Quart of engine oil every 500 to 800 miles! I don't see much on the ground. What I do see seems to be from the power steering at the right front of the engine (?).
Could I be USING that much oil without substantial engine performance problems (missing, etc.)? Thanks, ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
oil loss
Novice opinion here, but I'd think you'd be seeing plenty of blue smoke if you were burning that much oil. Maybe it's leaking only under pressure; that would explain why you don't see much of a puddle under the car.
dcb |
you said that it is at the right of the engine and appears to be powersteering??? Well I thought that something in my Powersteering was messed up with mine too when I saw this, but it turned out to be the valve cover gaskets... Check that...
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** ![]() |
LEAKING . . . . . . .
Maybe it is the right side valve cover gasket. They did driver's side gasket 1 1/2 years ago. I'll look closer!
I forgot to tell you that I use Redline 10/30 synthetic oil. ![]()
drive the car a few hundred miles without washing it. Then feel the exterior of the car (especially the back) for oil residue. Because of the aerodynamics of the svx, when you have a severe oil leak, it tends to just spray out under the car and become deposited on the rear bumper, tail lamps, trunk lid and the like.
Mike |
