#31
Iam just saying you can retard timing to a point, then you have to add more fuel to keep it from detonating to early, and you would have to add alot of fuel to run 10PSI in a SVX(pump gass) and not have engine damaging detonation. All your cars that have forced induction probely also have a way lower compression than the SVX.
#32
its limitless what you can do with a stand alone. To prevent detonation, you want to add more fuel esp under boost. A good rule of thumb is for every 2lbs of boost, you want to retard 1 degree. But with so many variables its hard to say. True, most of these other cars do come stock with lower compression, but they also run twice or more the boost levels.
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
#33
Id be more interested
in somehow mount an Intercooler somehow on the
car for increase efficiency and more hp. Fix that dillema and your thats half your battle.
#35
Definately any boost level beyond 6psi would require an intercooler, but at this level I agree with longassname, it would be more restrictive than beneficial.
As far as the timing topic, I think the timing would have to be retarded far enough and the mixture richened to the point that it would negate any effect higher boost would have. Combined with a propane injection system (107 octane equivalent) it might be possible, but that's just more cost, and that contradicts my goal for this kit. On the other hand, down the road after this is all settled, I'd consider it. Also, sent you an email Dayle, some questions about the kit on your site, for whatever its worth...
My two loves: SVX: 1992 Black LS-L, SS Brake Lines, Slotted/Drilled Front Rotors, Level10 Stage 3 Trans, 4.44s, Phantom Grip LSD PC: AMD Phenom 9950BE@3.0GHz, 4GB G.Skill DDR2, Asus M3A78-T, Radeon HD3850 512MB x2 Last edited by Reaper450128; 04-06-2004 at 05:34 PM. |
#36
6psi isnt even in the efficency range for a 16g!!!!!!!!! you CANNOT make that turbo make 6psi of boost on the stock wastegate. You will have to run an external, and i garuntee you that boost creep and compresser surge will be overwhelming. do it right or do it twice, t3/t4 or full t4 is doable.
phil
#37
I don't want to discourage you...but there are a lot of people here who know a LOT more about turbocharged engines htan you Reaper... and honestly, not everything you are saying is making sense, nor is it anything new. Thing is, turbo'ing the eg33 would require a LOT of custom fabrication. This is why almost nobody has done it, and why everyone is just saying 'prove it', because we're all sick of bench racing 'vaporware turbo kits'.
So basically... either make the kit..... or don't. - Rob |
#39
Hey, I'm fully aware of that. I also don't believe that just because people have failed at something in the past that it can't be done. If I'm wrong, that's fine like I said, but I believe it can work, and that it can be cheaper. No, I don't know a lot about turbocharging an engine, but its not a complicated concept either, I'll figure it out. And if there's anything I'm saying that doesn't make sense let me know and I'll look into it, maybe I'm wording it wrong or something.
Also, I'm tired of vaporware turbo kits too, that's one more reason why I'm looking into it myself. Do I know something no one else does? No, but maybe I'll see something no one else has in trying it, that's the only way anything new ever happens successfully.
My two loves: SVX: 1992 Black LS-L, SS Brake Lines, Slotted/Drilled Front Rotors, Level10 Stage 3 Trans, 4.44s, Phantom Grip LSD PC: AMD Phenom 9950BE@3.0GHz, 4GB G.Skill DDR2, Asus M3A78-T, Radeon HD3850 512MB x2 Last edited by Reaper450128; 04-06-2004 at 08:53 PM. |
#40
My two loves: SVX: 1992 Black LS-L, SS Brake Lines, Slotted/Drilled Front Rotors, Level10 Stage 3 Trans, 4.44s, Phantom Grip LSD PC: AMD Phenom 9950BE@3.0GHz, 4GB G.Skill DDR2, Asus M3A78-T, Radeon HD3850 512MB x2 |
#41
take a step back and realize what we are telling you. People who have a ton of experience with turbos know that making the svx turbo-charged is one hell of a task and definately not a weekend project. You are taking advive from a kid that knows a 2.0 4 cyclinder. Think for a minute, YOU CANNOT DO IT. As i mentioned before, i am a kid too, i know **** about cars. BUT, i don't try to prove professionals wrong because my friends thinks it can be done. The svx can be turbo charged, but it will take tons of fabrication, money, time, and know how, and nothing personal but it sounds to me and a lot of other people that you have none of these. Hey if you can do it, do it and prove us all wrong, but i got a feeling it won't be done on a Wal-Mart paycheck. Stop telling us what you might do and give us raw bleeding facts. Numbers are only weird shapes until aplied, make that your new modo. I'm sick of kids these days, makes me look like one of you idiots who thinks they know it all. Sell ur svx and buy an eclipse if you want a turbo.
#42
And Turbos care alot about how much boost they make, an internally wastegated turbocharger such as teh tdo04(4cm exhuast wheel)-16g cannot function at a pressure lower then 12 psi. You can try to mess wit hthe actuator rod, have it extended and what not. But hooke your trusty boost guage up to a posotive side feed and you will see that boost will spike well above what your expecting it to no MATTER what. Also, you wont have to worry about routing the wastegate, becuase the wastegate routes DIRECTLY INTO THE EHXUAST VIA THE FLAPPER GATE. It connects to the 02 houseing on a 16g, then the 02 to the downpipe. So you will need an 02 housing as well. Its going to need to be a ported 2g 02 sensor housing or an evoIII housing .. For the wet bearing, your going to need an scavenging pump to send the oil from the pan up to the turbo. you will also need to include a oil cooler in the return line. be sure that your bearing is located top to bottom(you cannot have the turbo laying at an improper angle, as the bearing will not fully utalize gravity). Water lines are straight forward and dont require an auxiliary cooler, just remember to tap before the radiator. Oil cooler would fit nicely aft the radiator. the cooler is absolutely a must for the oil!. A CT26 off a mkiii toyota supra is damn near a perfect fit . While their turbos are cheap they are known to sometimes have bearing failures. A nice hp gain and they run 8psi boost acutuated via an internal wastegate. If you find one in a yard i recamend taking the collector as well so you can adapt the flange for making your own "collector" Also do another search on my name and turbo and you should find in details some of the problems with running a single turbo on our manifold setup, why it creates boost spike, and some ways maybe you can work on getting rid of it. I believe its in one of chucks threads(cdiggerlando) on his turbo setup. Hey man, take or leave my critisizm. But alteast hear what im saying andi hope you can see past your anger or frustration with us. Just tryin to help.
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. Last edited by Phast SVX; 04-06-2004 at 11:32 PM. |
#44
Reaper-
You've really got to listen to these guys. They know their s***, and i really dont think you do. Please take their advice. ![]() Best of luck, Mike |
#45
![]() Will someone please make a turbo or supercharger that works well for our SVX...please? ![]() ![]() ![]() |
