Old 11-04-2005, 04:24 PM
SubaSteevo's Avatar
No longer blue member
Water Temp Sensor Location
My car is throwing the CE code for the water temp sensor, and sometimes is a pain in the butt to start. I did a search and found the part #, but does anyone know where the sensor is actually located? If you had/could take a pic that'd be helpful.
-Steve
01' MSM Lexus IS300
Old 11-04-2005, 04:48 PM
mbtoloczko's Avatar
sans SVX
I think its on the driverside of the engine back towards the firewall.
Mychailo
Visit my locker
Old 11-04-2005, 05:24 PM
Earthworm's Avatar
Meow!
Yes, it's also the 2 wire sensor.
Old 11-04-2005, 06:10 PM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
It takes about 10 minuets to replace. Drivers side under the back of the intake manifold.
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 11-04-2005, 07:56 PM
SubaSteevo's Avatar
Awesome
Does the intake need to come off to get to it?
-Steve
01' MSM Lexus IS300
Old 11-04-2005, 09:06 PM
AFBeefcake's Avatar
Subaru Swapper
nope.
I don't think you need to even remove the throttle body cover.
I replaced mine in the parking lot at work with only a ratchet and a rag in under 15 minutes.
The brown connector in the center of the pic is connected to the temp sensor.
2005 Legacy GT
Old 11-04-2005, 09:18 PM
SubaSteevo's Avatar
Originally Posted by AFBeefcake
nope.
Thanks!
-Steve
01' MSM Lexus IS300
