Old 12-14-2005, 07:51 PM
NeedForSpeed NeedForSpeed is offline
Maybe I can help? Certainly, the solution isn't to remove the steering wheel.
Originally Posted by pavanbabut
Hi Ron,
I am also not sure about it. Actually me and svxfile's brother Mark did that swap. But when I had given it to a transmission shop at first, they had taken apart all the axles, A joints and everything that connects to tranny and front wheels.
-Pavan.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 12-22-2005, 11:22 AM
pavanbabut's Avatar
pavanbabut pavanbabut is offline
Send a message via MSN to pavanbabut Send a message via Yahoo to pavanbabut
Hi,
Does anyone have any idea why a steering wheel goes off if it is never been removed or reinstalled? I didn't understand till now on how a steering wheel went that much off on doing a tranny swap. Any ideas where to check?
From my observations -
1) The # of turns for the steering wheel are same on both sides
2) The # of outer rings on the outer tie rod joint -
Driver's side - 4 rings Passenger's side - 7 rings
These should be ideally like 7 rings on both sides (accroding to svxfiles)
3) There are vibrations in my car while goin above 65mph
4) At the same time my steeering is shaking like a mad wheel (left and right).
5) Missing sub-frame flange bolt (Ordered it from the dealer and have to fix it tommorow).
thanks,
-Pavan.
Old 12-22-2005, 12:18 PM
Earthworm's Avatar
Meow!
1. is that from the proper steering wheel position?
2. not if something's bent in the suspension.
3. have you checked tire balance?
4. at least you know it's the front.
5. which one are you referring to?
Old 12-22-2005, 12:27 PM
pavanbabut's Avatar
1. No its from the present off position
2. But I never hit any thing nor it was in any collision
3. Yep I have given it at Sears a week before for tire balance
4. Yep, the only thing that I know to be replaced are the front axles as both the CV boots are cracked and I have ordered new set from rockauto and probably I will install them next week.
5. It is part #19 , the one near to the driver.
thanks,
-Pavan.
Old 12-22-2005, 12:35 PM
Earthworm's Avatar
Meow!
The rack is fine. It's where the steering column attaches to the rack. It needs to be disconnected and realigned. You've mentioned this in a previous post.
Old 12-22-2005, 12:44 PM
pavanbabut's Avatar
Yep some of the members suggested me to remove it and reinstall it. But we (me, svxfiles, mark, Needforspeed, Silverspear) think that reinstalling the steering wheel is not the correct solution to it as I or anyone else never removed and reinstalled the steering wheel. Tht's why I want to know how it goes off like tht without removing steering wheel and having tires balanced .
-Pavan.
Old 12-22-2005, 01:06 PM
Earthworm's Avatar
Meow!
You're not reinstalling the steering wheel. You're disconnecting the steering column from the rack to adjust.
I've never had my steering wheel off but I thought I read that it can only be installed one way. Can anyone confirm this is correct?
Old 12-22-2005, 01:15 PM
pavanbabut's Avatar
Can you gimme a rough idea on how this can be done? If this doesn't include removing of the steering wheel, I will give it a shot.
thanks,
-Pavan.
Old 12-22-2005, 01:31 PM
Earthworm's Avatar
Meow!
Never done it myself. I'm waiting for someone else to chime in now.
Old 12-24-2005, 10:03 AM
I just kept putting it on close until I got it centered, locked it down and put the airbag back on... Leave the airbag off until you get it absolutely centered. You are probobly going to need a puller to get it off... Something that hasn't moved in over 14 yrs. is gonna be stuck on pretty good
