Old 07-14-2006, 04:28 PM
Sr240sx's Avatar
Sr240sx Sr240sx is offline
hrm, couple new issues
A few issues that I'm not worrying too much about, but they're there
the car gets a shudder sometimes whilst driving or idling with the a/c on full bore... not used to this happening. and i don't believe it's from the compressor kicking on, because it happens fairly frequently. it's not very noticeable, but there.
second, the tranny wants to hold onto gears when you go at it full-bore. it gets to 6.5k and just sticks there, so long as you keep the pedal to the floor. backing off a wee bit lets it shift, but it shouldn't be hanging onto gears like that. normal driving is perfectly smooth and normal.
any thoughts?
My '95 SR20DET powered 240sx track car.
http://www.cardomain.com/ride/2161953
Old 07-14-2006, 05:14 PM
Earthworm's Avatar
Meow!
Sounds like maybe one of the radiator fans is vibrating.
As for the other issue I don't know.
Old 07-15-2006, 12:32 AM
Sr240sx's Avatar
rad fans are on there fine and tight o_o
Also, when accelerating around 45+ mph, it hesitates at about half throttle. give it some stick and it just starts behaving normally, but it wants to hesistate if you only give it half throttle...
Old 07-15-2006, 12:53 AM
Are your belts tight?
Old 07-15-2006, 10:39 PM
Sr240sx's Avatar
aye, they are.
Old 07-16-2006, 01:15 AM
Speedklix's Avatar
Locker Link Solution
Last time I had that happen not only did I find one engine mount was ripped in the back where I couldn't see, but it had also worked the nut loose... i'd start there.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
