Door Light Help
My driver side door light does not turn on when i open my door. But it does function when i do open the passenger door or lock it. (we now know there is power)
can somebody poit out to me where the sensor for the light is? My dash sees the door open but the light is still off? I took off my door panel and this is what happened. Thanks |
It could be that you may have messed up some wiring when you had the door panel off. This would appear obvious.
The sensor is inside the door lock mechanism. But if the dash shows the door open then it must be working.
Have you checked the "door" button on the ceiling console?
I don't think it would be the ceiling swtch because I gather all works OK via the left door. However worth a try. They that design car electrics are a wierd lot. Cheers Phil and another opportunity to thank you. Trevor.
But there is power, it does turn on when i use the door switch or turn the alarm. It just does not turn on when the door is open.
this has really have me stumped... is there a connector to the latch switch?? is it mechanical in nature? sensor? thanks |
There most certainly is wiring and connectors involved. I am not sure as to the exact nature of the switch/sensor, it could comprise read switch. Phil may have had physical contact with the animal. But is that detail relative? Best of luck, Trevor.
Hmm... the only thing I did was replace my power window switches.....
Just to clarify;
Drivers door open and Pass door closed = Drivers door light off Drivers door closed and pass door open = Drivers door light on Both doors closed and overhead switch on = Drivers door light on Both doors open = ???
I had my door apart last night so I had a look at the latch switch. The connector is the one that is visible when you look at the back of the latch through the hole in the door. It is a three pin plug (closed, common, open) but only the common and open pins are connected on my car. The plug can be a difficult to disconnect in the confined space of the door. You have to lift a little plastic tab to release it.
My advice is to check the connector. It that seems fine, unplug it and jumper it with a piece of wire. If the light comes on then the switch could be faulty. If not then there is likely a problem somewhere upstream towards the controller. Phil.
Ill take the door apart this weekend, ill try all the positions (no pun) suggested. Thanks guys.
