brake light in dash
ok some time the light comes up but them is doesn't not. Does anyone what i can do it make it just stop it.
Check your brake fluid level. When you take off the reservoir cap, make sure the rubber bellows is collapsed back into the cap and not extended. If it is just push it back in. If the fluid is low, fill it to the correct mark.
When the fluid warms up afterafter driving, it expands and the light goes off. When the fluid cools overnight, it contracts and it will read low. The reservoir has a magnetic float in it that operates a reed switch under it, to bring on the E brake light, when the fluid is low. The rubber bellows can hold the float down to bring on the light, just opening the top and folding the bellows back up, will turn the light off. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
well my brake fluid is filled up all the way. I'm thinking it might have to do with the wires in the back or some where around there.
ok so the brake light comes on intermitently and your fluid level is full? by any chance is it cold where you live? mine use to come on some times when its like 10 degrees out... i think its because i need to change my brake fluid
um the coldest that is get here is about 39
pop the cap of the brake fluid canaster. look at the cap, push the middle back into the cap (pushing the rubber bit back into its origonal shape)
That stopped my brake lite from comming on and felt like an idiot after that. Greg |
From your description this probably isn't what's happening, but if the light comes on only when you have your foot on the brake, you've got a blown or corroded brake light bulb.
dcb |
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore! Scott & Audrey's Subaru SVX's 1995 Green 1992 Black |
i think it might just have to do with the wire back there.
