New problem with my car....??
Hi,
After a long time, my car started giving me new problem. Last week, one day my battery went down low (Steering, battery, stop lamp, brake, ABS lights in the dash board came on). I tried to start it in evening and it started, but when I try to give it some gas it started to die slowly even I am giving it gas. When I try to start it again, it just started giving clicking sound. So I jump started it with my Alfa and it started right back again, so I thought it was a classic battery problem. Again this weekend me and my buddy (92svx95) planned to change the cam, oil and crank seals and thought I would have my battery load checked and went to autozone, there they said tht it is very low in charge. So since its already 4 years of its use we got a new battery. But, the lights were still there, but the strange thing is now the lights go off only between 1750rpms to 2000rpms. Then we swapped the alternators from his car (brand new one) and the lights went off, but this time we didn't test drive it. So, we got a new alternator for my svx too and didn't installed it as we thought we will once we are done with the seals. So, the seals are installed and the new alternator is in. Now I have my lights on again. But this time, they are not going off at those rpms, but they go off randomly. They stay on most of the time and they go off slowly when I reach 6k rpms. Sometimes the abs light goes off while the others are on and sometimes it blinks and sometime it stays on. Any ideas wht going on here....?? thanks, -Pavan |
Just a thought, what was your altanator mod? Maybe try removing it to see if it is the culprut?
-=SM |
If the dash lights are coming on then the diodes in the alternator have failed. A bench test for bad diodes will confirm this. Resolved by having the rectifier replaced.
-Pavan. |
Correct
My nephew had the same light problems and got a rebuilt alternator from AutoZone. After driving a very short distance---same lights on problem with the new one. End result was that the newly rebuilt alternator was bad also. Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX L Pearl (Body-rust free) 20 F150 4X4 King Ranch FREEDOM IS NOT FREE |
Have them check the regulator, rectifier and wiring between the battery and alternator. Also check that the alternator belt is not slipping.
The dash indicator lights test circuit, incorporates blocking diodes to eliminate a sneak circuit which would otherwise exist. In an event involving faults within the alternator rectifier network, alternating current is induced on line. The result is pulses of reverse voltage, which pass the blocking diodes in the test circuit and energise the indicator lights.
Bad ground?
Try checking the ground that is in front of the battery, where the battery lays. Mine was loose and corroded. I cleaned it up and it fixed all my electrical/lights on problem.
Hope this helps. Ken |
Ok here is a clip of the problem.... check that the lights go off when I rev it up... I will check with Ken92SVX suggestion, becos I know that mine is also corroded, but I am not sure thats causing this.. but we never know..
Video Clip thanks, -Pavan |
I had a problem just like this 2 times with 2 diffrent problems. THe first time it was my harmonic balancer going bad...so it would free spin sime times. then about a month later the alt. that I bought at advance thinking it was the problem the first time took a crap...I got 2 bad alts. before they gave me a good one....I ended up taking a old svx alt to a shop and had it rebuilt and it has been all good ever since.... hope this helps
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs |
-Pavan |
I'm also having the exact same problem as Pav (it's amazing how far one can drive on just a battery ) I'm thinking that its more then just the diodes though because when I check voltage at the alt. output it is only battery voltage which leads me to believe that the voltage regulator goes out shortly after the diodes fail.
Now if I could just find a rebuild kit....... Every auto place just wants to sell you a rebuilt.
