Old 03-05-2007, 02:08 PM
AlcyoneDaze's Avatar
AlcyoneDaze AlcyoneDaze is offline
<-- custom hood ornament
Send a message via AIM to AlcyoneDaze Send a message via Yahoo to AlcyoneDaze
Exhaust Scraping
http://www.subaruparts.com/subaru.diag/2/i440-A.gif
Hi all,
I was changing the oil and inspecting my o2 sensors yesterday when I noticed both of my front exhaust pipes are scraped and bent somewhat. The pipes I am talking about are directly between the exhaust headers and the catalytic convertors (where #7 and #14 attach in diagram) Does anyone know the part numbers for these? They are bent enough that I think it may hamper performance/emissions. Please Help!
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L
Donating Forum Member In Good Standing
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 03-05-2007, 02:14 PM
To clarify, the pipes that the o2 sensors plug into, they are bent. What are they called, whatz the part number, and should I bother?
Old 03-05-2007, 02:32 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
check if you have an exhaust leak. you could probably hear it.
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 03-05-2007, 02:34 PM
no exhaust leak. The car still sounds normal...
Old 03-05-2007, 02:53 PM
is your car dropped? have you noticed any scrapping sounds before? speed bumps maybe?
my car is dropped and i really have watch where i go. especialyl for speed bumps and pot holes
Old 03-05-2007, 03:04 PM
No, stock ride height, but I live out in the sticks, the last thing I remember scraping was a rather steep driveway incline, maybe a curb or two. There is no holes in it, each pipe on both sides are just bent in and have curb rash.
Old 03-05-2007, 03:08 PM
well...as long as it doesn't seem too bad, then i guess you would be ok.
Old 03-06-2007, 06:35 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Those look like the precat pipes..your diagram should have the p/n on that website page from subaruparts.com or should be in the vicinity of that website page.
Are you throwing any C/E codes?
1995 Subaru Svx L / AWD
Old 03-06-2007, 06:43 AM
msvx95's Avatar
It's just a phase
I think you are looking for the exhaust manifold part numbers...the short elbow pipes that come from the block?
The p/n's I found are 14009AA001 and 14022AA000
They go into the converter assembly 44107PA240 which is the diagram you are looking at.
Someone correct me if I'm wrong.
thanks
Old 03-06-2007, 08:37 AM
i was assuming he was talking about the heat shields
Old 03-06-2007, 11:47 AM
msvx95's Avatar
It's just a phase
its the pipes as he stated above, not the shields.
looks like you have to order the whole assembly heat shields included.
44107PA240
Old 03-06-2007, 12:09 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I'm with DoD...you'd have to hit pretty hard to actually bend the pipes. The heat sheilds definitely get bent up over the years and will not affect the exhaust system's performance. If the pipes are, in fact, bent up, then you're better off going to a custom exhaust shop and having new head pipes bent/welded up.
Check SVXFile's locker ("Harry's car") for the new system he just did for NEWSVX's car.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
